Old 02-25-2013, 03:28 PM   #21
Bruce Lancaster
Default Re: Flathead project
Heads off...freeze plug bulges confirmed...'39-40 221
Bruce Lancaster is offline   Reply With Quote
Old 02-26-2013, 06:02 AM   #22
LSJUNIPER
Distributor, water pumps, oil pan removed, yuk!!!! what a mess in side the block...sludge city!!! LOL!!! So far I can't see any cracks.
LSJUNIPER is offline   Reply With Quote
Old 02-26-2013, 06:31 AM   #23
Mart
Mart's Avatar
Took the head gaskets off yet?
Mart.
Old 02-28-2013, 05:57 AM   #24
LSJUNIPER
Mart,
I left the head gaskets on for now, to protect the mating surface from being damaged while taking the motor apart.
Old 02-28-2013, 06:04 AM   #25
LSJUNIPER
I think this motor has had work done to it in the past, found one of the tappets to be slotted, the rest are the non slotted type..
Old 03-04-2013, 05:53 AM   #26
LSJUNIPER
Some more pics,
Old 03-04-2013, 05:58 AM   #27
LSJUNIPER
And more, Almost ready to bring the block to the machine shop for claeaning and a mag test for cracks. If all OK then a pressure test...I desided that I will bring the block to Eastwoods Auto Machine...
Old 03-04-2013, 06:09 AM   #28
39portlander
39portlander's Avatar
The last "Flathead" I tore down and got to this point, pulling the pan was painfull. It had the dreaded pan rail cracks on both side
39portlander is offline   Reply With Quote
Old 03-04-2013, 07:15 AM   #29
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Hey Phil, up here in Me. the salt water is alot cooler than it is in Florida. the clams have to bury in the mud the keep warm. LOL Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 03-04-2013, 07:24 AM   #30
Walt Dupont--Me.
I don't see any sign of the steel sleeves in the bottom end pic. If it's still 3-1/16 I'd call it a 39 engine. Walt
Old 03-04-2013, 11:48 AM   #31
LSJUNIPER
Walt, there isn't any sleeves, I will call it a 39..No cracks in the block that I can see...
Old 03-11-2013, 04:54 AM   #32
LSJUNIPER
The block does not have any cracks in it and it passed the pressure test. More pics...
Old 03-11-2013, 06:07 AM   #33
Mart
Mart's Avatar
Looks very nice. Congrats on the crack free status. What process did they use to clean it up?
Mart.
Old 03-11-2013, 10:28 AM   #34
LSJUNIPER
It was dipped in a hot tank about 3 times, 2 days per dip. Mark at Eastwoods auto said it was a dirty block. After the hot dip Mark pressure washed it. He then rough bored the cylinders .030 over.
Old 05-29-2013, 05:00 AM   #35
LSJUNIPER
Update, the motor is home from the machine shop, Eastwoods Auto Machine in Somersville CT. Took the advise of quickchange34 and mart and made a bracket to hold the motor from the exhaust ports...see pics...Thanks
Old 05-29-2013, 06:13 AM   #36
Walt Dupont--Me.
I keep looking at the intake manifold surface on the block, Of all the pic I still cain't tell if it's a raised intake surface, in some of the pic it looks like it does. But, the engines with a raised surface were late 41-42 and had sleeves, so with no sleeves I'd call it a 39. Walt
Old 05-29-2013, 10:25 AM   #37
LSJUNIPER
Walt, Yes it's a 39. Went to VanPelt sales webpage and I was able to figure it out by there section on how to ID a flathead motor....
Old 05-29-2013, 12:56 PM   #38
Barn Junk
Barn Junk's Avatar
I see the head studs have been removed. Did this present any problems? It seems like the hardest problem with the crusty blocks I have worked on.
Barn Junk is offline   Reply With Quote
Old 05-29-2013, 01:58 PM   #39
LSJUNIPER
I did try and remove the head studs myself, but they wouldn't budge. When the block was dipped into the cleaning tank the studs then were able to be removed. I had the machine shop remove them and two of them had to be drilled out.
Old 05-29-2013, 02:04 PM   #40
Mart
Mart's Avatar
Just a little warning - don't run a tap down the head stud holes - they are a tight thread and a tap will open them out. Use a thread restorer or an old stud or bolt with a slot cut in it.
If you already knew this I apologise, but it isn't obvious to a novice.
Mart.
