Old 01-27-2013, 11:45 AM   #21
Richard Wilson
Richard Wilson's Avatar
Default Re: Who Can Diagnose THIS Total Mystery? Win A Prize?
Funny story but similar symptom. When we were kids my brother put a crab apple in to the gas tank of dad's Model A. Dad would drive a week or maybe 5 minutes and the engine would suddenly die. Took dad a long time to figure out the problem as the apple would roll around and some times it would be exactly over the outlet shutting off the gas flow. Take a flashlight and check out the inside of your tank.
Richard Wilson is offline   Reply With Quote
Old 01-27-2013, 11:57 AM   #22
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Holy Cow!!!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-27-2013, 12:05 PM   #23
160B
160B's Avatar
Could be a bad coil
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 01-27-2013, 12:17 PM   #24
sgwilson904
Thanks for the suggestions, Guys! Keep 'em coming...there's an answer in here somewhere, I know it! And I'm pretty sure it's not a crabapple in my fuel tank...still wondering if that brother survived Father's discovery? lol
Interesting suggestions about a bad coil which I got new from Snyder's. Apart from replacing it, is there any way to TEST a coil? Also, what about condensers? How would you test one of those?
sgwilson904 is offline   Reply With Quote
Old 01-27-2013, 12:19 PM   #25
700rpm
700rpm's Avatar
I will say intermittent short, probably the distributor plate as mentioned several times; I'll be surprised if it's a fuel problem. I have always believed, and it has proven true in my experience, that most "carburetor problems" are electrical.
Ray Horton, Portland, OR
Old 01-27-2013, 12:31 PM   #26
P.S.
Simple.
A higher end voltmeter will usually have a capacitor test function. Or, you can purchase a capacitor tester.
The condenser in your car is basically a .25 uF capacitor. It should test at or near this value, and should show no leakage if good. Leakage is tested with an ohm meter (or a voltmeter with ohms setting).
When initially connecting the capacitor for leak test, the resistance (ohms) should be pretty low, but will charge quickly and show infinity (many megohms) and look like an "open circuit" within a second. if not, then it is leaky.
You can use a heat gun to heat the capacitor while under test and check to see if its value or leakage change with heat. If good- Its value should stay within 5%, and should never show signs of leakage regardless of temperature.
P.S. is offline   Reply With Quote
Old 01-27-2013, 12:33 PM   #27
Tinbasher
Tinbasher's Avatar
Check the voltage coming out of the generator. You could be overcharging the system causing the condensor and coil to get hot and cut out.
My two Cents worth. Tinbasher
Tinbasher is offline   Reply With Quote
Old 01-27-2013, 12:49 PM   #28
Gary WA
Gary WA's Avatar
We are having the exact same problems on this vehicle as we speak for the last few weeks and still cannot find the answer!!! But we are moving on!!! Been on here under "backfire" which it doesn't do DOUBLE THE PRIZE!!!!
www.whidbeymodelaclub.com
Old 01-27-2013, 12:53 PM   #29
H. L. Chauvin
In a way you are lucky to have a 10 minute interval where the engine dies which gives time for diagnosis.
No matter how many thousands of items are replaced, verified, adjusted, checked, tightened, cleaned, or repaired, please remember that the engine stalling end of the line is "always" in the combustion chamber.
The combustion chamber is like Harry Truman, mostly ignored; but this is where the Buck stops.
If one finds either an "electrical" problem or "fuel" problem where it really counts in the combustion chamber, & you are 50% ahead in valuable repair time & costs.
H. L. Chauvin is offline   Reply With Quote
Old 01-27-2013, 01:22 PM   #30
Mitch//pa
as mentioned in my above post install a spark tester inline of the coli wire and observe the intensity and pattern when acting up vs running good to determine if the problem lies in the ignition
Old 01-27-2013, 01:30 PM   #31
ct1932ford
ct1932ford's Avatar
Coil!
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 01-27-2013, 01:42 PM   #32
SkimmerBob
SkimmerBob's Avatar
Now thats a statement! I love it!
And that is one sweet double!
SkimmerBob is offline   Reply With Quote
Old 01-27-2013, 02:07 PM   #33
Hicktick
Hicktick's Avatar
I would drop the exhaust and try it , the muffler could be causing your symptoms .
Hicktick is offline   Reply With Quote
Old 01-27-2013, 02:15 PM   #34
Carbroke
Bad coil. When it heats up it quits, then works when cooled a bit. Send it in for repair or find another coil .
My 2 cents worth.
Carbroke is offline   Reply With Quote
Old 01-27-2013, 02:20 PM   #35
BarracudaBoy
Mine had similar problems. Overheated sometimes, a lot of backfiring. I pulled out the aftermarket screen in the fuel tank outlet after I figured out there is a screen in the top of the fuel bowl. I suspected that junk was being pulled against the screen choking off the fuel flow. In the end it was the carb float level being set to low. Henry's filtering system seems to work well. I wound up getting a quarter bowl of junk in the bowl.
Try this site. Good info!
http://www.model-a.org/troubleshooting_chart.html
BarracudaBoy is offline   Reply With Quote
Old 01-27-2013, 02:37 PM   #36
JBohannon
Check to see if at any point your fuel line is very close to the manifold or exhaust pipe. You could be getting heat from their at any outside temp which might cause vaporlocking.
JBohannon is offline   Reply With Quote
Old 01-27-2013, 02:45 PM   #37
700rpm
700rpm's Avatar
Would an overheated coil cool down enough in ten minutes to alleviate the problem and continue on down the road? I've never experienced a hot coil, so I am just curious.
Old 01-27-2013, 02:53 PM   #38
KR500
KR500's Avatar
I always like Tom's ,what I feel are well founded diagnostic habits, and one thing I have learned is Test, Don't guess. I didn't see or read anything here if the coil was heated and tested. Possible breakdown after heating would cause the symptoms you describe. I also don't like parts changes with out testing the suspected parts that may be bad. If you suspected fuel delivery problems install a small auxiliary gas tank(quart or half gallon ) and go test drive. Heat can do funny things as far as resistance in circuits as well. Good Luck and DON'T walk away from a challenge!
KR500 is offline   Reply With Quote
Old 01-27-2013, 02:59 PM   #39
Bud
Bud's Avatar
I had a professionally restored popout switch give me the problem you described. I had to stop 3 times in 50 miles on the maiden voyage of my town sedan. I replaced the popout switch with the reproduction on-off switch and it has run fine for the last 16 years.
Bud is offline   Reply With Quote
Old 01-27-2013, 03:04 PM   #40
George Miller
George Miller's Avatar
When it starts misbehaving this way, twisting the choke rod to add fuel to the carb seems to have little effect. Pulling the choke rod out about two-thirds of the way (flooding it with gas) will cause it to sputter a little less and limp a little farther.
__________________________________________________ _____________________________
If what you say here that pulling the choke helps, then it is gas not electrical. If it was electrical pulling the choke would have no effect.
Check and see if the gas line is in the carb or filter to far and blocking the flow of gas.
George Miller is offline   Reply With Quote
