Old 12-08-2012, 07:30 PM   #21
steve s
steve s's Avatar
Default Re: Centrifugal Advance
Originally Posted by harleyjj View Post
steve s. what is the round ball mounted on the sunvisor of the car in the above picture for?
I have no idea. One of the many things I wish I had the opportunity to ask my dad about.
Steve
steve s is offline   Reply With Quote
Old 12-09-2012, 02:18 AM   #22
Growley bear
Henry must have realized the advantages of a centrifugal distributor advance mechanism fairly early on as the model B was equipped with that feature. My model A, at present with the advance not operating through the full range of advance drives much smoother and responds more quickly to the accelerator pedal, at least up to 30 mph then I have to use the column lever for more advance.
I'm thinking that the lifter chamber cover may not have proper clearance and is not allowing the Taurus to move through the total 30 degree range. I won't know until after the first of the year.
I've driven in that sort of traffic; very hard on clutches too.
Chet
Growley bear is offline   Reply With Quote
Old 01-15-2013, 11:24 AM   #23
Growley bear
A follow up on the Model A centrifugal advance assembly which installs in the valve chamber is as follows.
I removed the side cover which is a full flow oil filter mod. which I installed at the same time as the advance kit. There is no sign of any interference with the rotation of the shaft or taurus. I was given the option to recalibrate or have my money refunded along with ALL shipping costs. I will get a refund. I'm not here to reinvent the Model A. This is for information only, I'm not looking for advice, Thanks,
Chet
Old 01-15-2013, 11:36 AM   #24
mccsix
mccsix's Avatar
OnStar antenna
Gene
USN
mccsix is offline   Reply With Quote
