Old 08-15-2012, 05:27 PM   #21
RonC
RonC's Avatar
Default Re: spray cans
appliance paint works great on carburetors but haven't seen semi gloss black in a long time.
RonC is offline   Reply With Quote
Old 08-15-2012, 07:10 PM   #22
glenn in camino
glenn in camino's Avatar
My favorite is gloss black rustoleum. I also use Krylon satin black on my radiators. I paint the bigger stuff with quarts of rustoleum in my spray gun. Question, is the appliance Rustoleum really gasoline proof.
glenn in camino is offline   Reply With Quote
Old 08-15-2012, 09:40 PM   #23
PetesPonies
PetesPonies's Avatar
Lots of ways to do this and lots of opinions. Many of what has been mentioned, I have done at times. Newer Rustoleum engine paints dry much quicker than older Rustoleum paints. Epoxy spray can paint works OK too ( not really a 2 part epoxy, but OK ). However, if you really want a durable hard surface that resists any chemicals, I would use either of these two paints. You can actually brush it and it will not look like it has been brushed. But those of you with spray guns, air brushes even, can spray it.
http://www.masterseriescoatings.com/index/black/
http://www.masterseriescoatings.com/index/ag111/
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
Old 08-15-2012, 11:09 PM   #24
Doug in NJ
Doug in NJ's Avatar
Originally Posted by Stretch Cab View Post
What about Eastwoods Chassis black???
I used the Eastwood Extreme Chassis Black (and its matching primer) for many chassis parts, in either gloss or semi-gloss as required. After drying overnight, I would bake the parts in the oven for an hour or so at 180 degrees. After that, the paint was very, very hard, and I have had no problems with peeling or chipping.
But the stuff is pricey, and if I were starting another restoration, I might experiment with baking appliance epoxy and see how it compares.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 08-16-2012, 07:21 PM   #25
Robert
I prefer Duplicolor...dries quickly and smells better than the competition.
Robert is offline   Reply With Quote
Old 08-17-2012, 12:22 AM   #26
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
I use Rustoleum "Painters Touch" line. The can is black on the bottom, white in the middle and a blue stripe around the top. They claim 2X coverage. It covers well and dries very quickly.
I like the red oxide sandable primer and the semi gloss black but I think it comes in high gloss too.
I also like Eastwood Chassis Black. It is epoxy, needs no primer, dries to a semigloss and is tough. It's pretty pricey compared to Rustoleum
Richard
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
