Old 02-09-2022, 03:45 PM   #21
Cartravel
Default Re: Fuel Gage - volatge senstive?
I am starting on gauges for our '40 pickup. I've read a lot of posts on this subject, so I think I understand most of the issues. I will have to use an aftermarket gauge, since the original will not fit into the new tank. I've gotten a couple of sending units recommended here (Carpenter and Yogi's). I've also gotten some of the MC7806 voltage regulators ($0.39 each). I've got 4 different gauge clusters, but most sat out in the weather and look nasty. I need a good working gauge to figure out how to adjust the sending unit arm length and height. How can I test these gauges to find one that works? Can I briefly touch 6v across the contacts to see if the needle moves? When they don't work what is normally the problem and how do you fix it?
Cartravel is offline   Reply With Quote
Old 02-09-2022, 08:42 PM   #22
JSeery
JSeery's Avatar
Use a 1.5 volt battery and you should get a half scale reading
Old 02-13-2022, 08:05 PM   #23
Cartravel
I played with several gauges today. With the face off, the oil pressure and fuel gauge appear to be identical. The temperature gauge appears to be a mirror image. All measure about 10.5 ohms through the windings, however, the needle doesn't move with 1.5 volts. So I still don't know whether I've got any good gauges, but the consistent 10.5 ohm measurement suggest they should work. Any ideas?
