09-01-2014, 11:39 AM | #21 | |
Re: Turn signals with hidden switch
You need one made for low current draw. look up LED Bulb Electronic Flasher.
09-01-2014, 11:44 AM | #22 |
I just finished installing the Bratton's set up on my 1928 speedster! Nice install and I modify the bracket so I can use it on any type of Model A Ford
Mike IMG_1461.jpg IMG_1462.jpg IMG_1463.jpg IMG_1460.jpg |
09-01-2014, 12:03 PM | #23 | |
http://ronsmachineshop.net/Hidden_Turn_Signal_Kits.html |
09-01-2014, 12:25 PM | #24 |
I am very happy with my Smart Signals.
http://smartsignals.com Completely made in the USA. Easy to install for driving. Easy to remove for show. I am not affiliated with Smart Signals in any way, just a happy customer.
09-01-2014, 03:15 PM | #25 |
700 rpm,
can we get a pic of the rear lights ? mike |
09-01-2014, 03:57 PM | #26 |
I've got one set, and I just move them from car to car. The company is way backordered right now. Call them to get a delivery date.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. Last edited by 700rpm; 09-01-2014 at 05:56 PM. |
09-01-2014, 04:25 PM | #27 |
This one looks great if you are upgrading to LED taillight lenses or bulbs.
No need to add any additional rear turn signal lights as you can use your standard rear duolamp housings with LED lights inserted as standard tail, stop and turn, (great brightness for daytime driving.) LEDs use much less current. (good for 6 volt systems) http://www.logolites.com/
Simplicity is the ultimate sophistication. L.D. I have 40 horses in the garage. Only feed them when I want to take them out. 31 Model A Tudor 55B Nick |
09-02-2014, 01:02 PM | #28 |
Mike you are right...led electronic flasher is needed. thanks for there tip --- I will look around for one.
Using the standard heavy duty flasher --- only the hazard flashers work (front and back/3rd brake light). Directionals only -- do NOT get enough voltage --- only around 2.5 volts. and do NOT work. BTW -- the standard heavy duty flashers are very unpredictable --- checked the ohm reading of L to X terminal -- should be zero when cold and instead was over 8 ohms. these units are real junk. |
09-02-2014, 03:38 PM | #29 | |
09-02-2014, 10:40 PM | #30 |
Got mine about Feb 2014. I had about an 80 day wait. Worth it in the long run, for me.
