Old 01-13-2012, 12:42 PM   #21
Modelakid31
Send a message via AIM to Modelakid31
Default Re: Most helpful or amazing thing you've learned
A lot of stuff over the course of my Tudor restoration! And still learning. No one person will every know EVERYTHING about these beauties.
Modelakid31 is offline   Reply With Quote
Old 01-13-2012, 12:47 PM   #22
jkeesey
jkeesey's Avatar
Best hint I've been given is when screwing into interior wood soap the treads and the screws go in easier, I've never been a good carpenter. And my favorite, on an old car if there's a possibilty it could be screwed up or done wrong somebodies probably done it.
jkeesey is offline   Reply With Quote
Old 01-13-2012, 01:00 PM   #23
Russ/40
Russ/40's Avatar
I've learned I always do it better the second time, so I just do everything twice.
Russ/40 is offline   Reply With Quote
Old 01-13-2012, 01:07 PM   #24
Bruce in southern OH
Bruce in southern OH's Avatar
Don't Drive Faster Than Your Angle Can Fly!!!!
Bruce in southern OH is offline   Reply With Quote
Old 01-13-2012, 01:20 PM   #25
700rpm
700rpm's Avatar
I learned that beeswax is better than soap; soap will attract and hold moisture, and eventually rust the screw.
I also learned that incorrect timing can adversely affect your main bearings; get the timing right!
Ray Horton, Portland, OR
Old 01-13-2012, 02:09 PM   #26
Jake
Jake's Avatar
Talking Re: Most helpful or amazing thing you've learned
If at first you don't succeed you dindn't do it right...
Jake is offline   Reply With Quote
Old 01-13-2012, 02:22 PM   #27
HoarseWhisperer
HoarseWhisperer's Avatar
I've learned that the Model A engine has magnetic properties.
Opening the hood will attract Model A "mechanics" from a 100 mile radius, scratching your fenders in the process.
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 01-13-2012, 04:41 PM   #28
hardtimes
hardtimes's Avatar
Originally Posted by Roadster62 View Post
Removing hood hinge rods with an electric drill and BP Blaster is one.
Yup, this is one of many !
I liked the idea of a guy who used hardwood 'dowel' pins as replacement rods...soaked the dowels first. Inovative !
BTW-
I used an alternative to the 'wooden' rod version: I bought solid aluminum rod same diam as original rods, at hardware store (Lowes). Cut to length. No need to lube/paint at all , as it is bright. I found that this method....light weight, no rust or appreciable wear and works great !
hardtimes is offline   Reply With Quote
Old 01-13-2012, 07:18 PM   #29
1crosscut
1crosscut's Avatar
Put your tools away every time so you can find them every time. Still working on that one.
1crosscut is offline   Reply With Quote
Old 01-13-2012, 09:20 PM   #30
KGBnut
KGBnut's Avatar
Originally Posted by BILL WILLIAMSON View Post
I learned that screwing the mixture screw in, is not lean, but is RICH!
Wait a second.... Are you talking about the Choke/GAV control? Turning that in makes the mixture more lean.
Suddenly I'm feeling like I'm not in on the gag.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 01-13-2012, 09:38 PM   #31
Purdy Swoft
Purdy Swoft's Avatar
I would think that he is talking about the idle air adjust screw on top of the carb. When the idle adjust screw is turned in it decreases the air to the idle circuit and richens the idle mix.
Old 01-13-2012, 10:19 PM   #32
Milton
Milton's Avatar
Don't hand crank the motor with the spark advanced and your tongue hanging out.
Milton is offline   Reply With Quote
Old 01-13-2012, 10:48 PM   #33
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Don't clean the screen on the front of the Zenith carb on THE CAR!! Crud can dislodge & plug up the top of the needle & seat. Mine plugged by a little black BEETLE.
Clean this screen ONLY with the carb off the car, and/or apart!! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-13-2012, 11:07 PM   #34
Reds34
Don't pee into the wind. I've also heard of putting wax on the bottom of drawer slides so they slide easier.
Red
Reds34 is offline   Reply With Quote
Old 01-13-2012, 11:44 PM   #35
modeleh
modeleh's Avatar
If you have a starter bendix stuck in the ring gear, put trans in high gear and yank the vehicle ahead with a strap. Install modern bendix.
modeleh is offline   Reply With Quote
Old 01-14-2012, 02:13 AM   #36
BILL WILLIAMSON
NO, NO,
High gear, and BACKWARDS!!
Old 01-14-2012, 10:34 AM   #37
modeleh
modeleh's Avatar
yeah, I think you're right. First time I did it, now that I think about it, it was backwards, per advice that I got by asking a question on the old fordbarn. Then it happened again when I was at a gas station, I happened to be at the front of the line, so I got yanked ahead, and it freed up the starter. It started right up after that, then several times again until I got tired of rolling the dice. After that the modern bendix went in. A pretty helpless feeling when you step on the starter button only to have it lock up the engine when you're miles from home.
Old 01-14-2012, 10:47 AM   #38
JoeWay
JoeWay's Avatar
yeah, I think you're right....
No. Modeleh, you were right the first time.
The starter pinion is "coming from behind" so to speak, trying to push the ring gear in the forward direction. If it sticks, it is on the back side of the ring gear teeth. The ring gear should be pulled forward, off of the pinion teeth.
If the pinion had made it to the forward side of the ring gear teeth, it wouldn't be stuck.
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 01-14-2012, 10:55 AM   #39
Ross/Kzoo
Ross/Kzoo's Avatar
Do we need an opinon poll on this?
Ross/Kzoo is offline   Reply With Quote
Old 01-14-2012, 12:56 PM   #40
Fred K-OR
Fred K-OR's Avatar
Originally Posted by Jason in TX View Post
Most helpful to me is Marco's timing procedure. Always sharing that with people who don't know why their car has no power and backfires a lot.
This in only one thing I have learned and is very helpful. Thanks Marco.
Any one who has not used this method should at least try it. Simple and great to use "on the road" if needed.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
