#21 |
This is the operation on undercutting the valve.
#22 |
Nice pic Ron. Are you useing a stock valve with the shoulder and cutting that shoulder off and undercutting under the head? I oftened wondered if these were 2 piece valves. If so will thay stay together? Walt
#23 |
those look nice..........im confused now? in JOE ABBIN's blown flathead (his first book). his flow charts show the 1.6 flowing better at low rpm?
#24 |
Walt I took these pictures along time ago and yes i understand all these exhaust valve are two piece. Not sure about the intakes. I was ay TRW and wtched this operation it's called friction welding. I just run that carbide down the stem and backing out at a 20 deg angle leaving about .90" for a seat. This and the combustion chamber work was included in all my engines, Not sure how well it worked, but most are still running.
