#21 |
Would the bowl vent make a difference. I know one would leak into the carb and the other would leak outside if the float stuck or there was some percolation.
#22 |
Thats not what i said,read it again. How can you set points out of the dist???????. I said the coil must be on the dist when you set points. ken ct.
#23 |
#24 |
WOW ! some of you guys make an old ford V8 ignition sound complicated. Im an older (not old) retired auto electrician and own a stock origional 1934 four door and it runs an 8volt battery system which has been in it for over 5 years. last set of distributer points have been 4 years. It has an original stock ford coil (not rewound). I once fitted a 6volt battery in it to do voltage and current comparison readings on the ignition system. Coil current draw was only about 5% higher on 8 volts using the standard ford resistor under the dash. Cranks over fast and starts instantly from cold,(Bonney & Clyde would be impressed). Lights are all standard bulbs and are very good. Only blown one stop light in 5 years. Generator will handle 8 volts easily. Just set the third brush up on generator to charge a max of around 6 amps total (ignition will pull about 3 amps of this) leaving 3 amps into battery for daylight running. DONT DITCH THAT 8 VOLT BATTERY. My car also ran fine with the 6 volt in it but the 8 volt was in it when I bought the car. Spark is bright blue even with resistor plug ends which are there to stop ignition noise in the origional glove box radio. Runs great even on 90 +++ degree day. I must have a good one !!!!
#25 |
I don't know about complicated. 6-Volts worked just fine until the 8-volt systems were developed for GPWs. If your starter doesn't turn over well, its likely the starter needs overhaul or a crusty cable or terminal connection somewhere.
If more voltage is needed, go with 12-volt. At least modern electronics are compatible with that. 6-volt gauges and radios last longer on there intended design voltages. A 34 Ford with a 3-brush generator is less suseptibel to probelms than the later cars with voltage regulated 2-brush generators, multiple heated element gauges, and radios with weak vibrators. Kerby Last edited by rotorwrench; 08-06-2011 at 10:32 AM. Reason: added info |
#26 |
