Old 05-11-2026, 05:26 AM   #21
Werner
Werner's Avatar
Default Re: aluminum timing gear recommendation
Originally Posted by updraught View Post
Anyone know why Antique Engine Rebuilding would not use a metal gear?
This is because the risk involved in installing a plastic gear is significantly lower. With a metal-on-metal setup, much tighter tolerances are required. If the flank clearance is too tight, you will experience rapid wear; if it is too loose, you may hear a slight clicking soound.
Therefore, as a precautionary measure, the crankshaft gear should also be replaced whenever a metal camshaft gear is installed.
The plastic gear is more forgiving of errors because it runs more smoothly.
When I had to replace the Novotex gear in my engine six years ago—because it was severely worn—I opted for an aluminum gear instead. It was available in a slightly oversized version, designed to compensate for the clearance in a used crankshaft gear.
During the engine overhaul earlier this year, I reused that same gear. It worked out well; I don't detect any bothersome noises.
Meanwhile I think, that was a bit of luck, too.
However, if I had to make the choice again today, I would go back to using a Novotex gear. That way, you eliminate the risk that the gear pairing won't be optimal. And for a classic car, the shorter service life is of no consequence.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 05-11-2026, 06:41 AM   #22
Big hammer
AER engine, 6.0 head, large valves, touring cam, 5-6 years later the fiber timing gear let go in one spot , where spark occurs. I run the timing advanced when on a long uphill climb it will spark knock sometimes having to retard the timing by hand . At replacement time no fiber gear available went with an aluminum gear from Brighton‘s .
get a bigger hammer tap done
Old 05-11-2026, 10:28 AM   #23
ModelA29
ModelA29's Avatar
Originally Posted by johnneilson View Post
Materials, sure to be different, but Dan is a craftsman and that is reflected in finish and more importantly tolerances maintained.
I have stacks of metal gears, some are just better than others.
John
Very true. I have one of his bronze gears - just waiting for an engine that is worthy of using it in.
ModelA29 is offline   Reply With Quote
