Old 05-08-2026, 05:42 PM   #21
Jeff/Illinois
Jeff/Illinois's Avatar
Default Re: Fuel line question - UPDATE
Another trick is take a cast iron Zenith carb, remove the brass fuel filter, replace it with a bolt that will screw in about 2 inches long. Then put your ferrule on the end of the line and snug the fuel line down good. It will seat that ferrule the proper distance from the end of the fuel line.
Take the bolt out take your fuel line out of the Zenith, install it on your Tillotson you should be good
Jeff/Illinois is offline   Reply With Quote
Old 05-09-2026, 12:48 AM   #22
JayJay
Originally Posted by RENNERS CORNER View Post
From the Ford drawing !!!
Were are people coming up with some of this stuff they are posting ????
Certainly looks like an original drawing, but I wasn’t aware that Loctite was available in 1930’s? I think the company started in the 1950’s.
I also think that superglue (cyanoacrylate) is a relatively recent invention.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 05-09-2026, 08:27 AM   #23
rotorwrench
rotorwrench's Avatar
That illustration shows the B part numbers. The A9243 was used from the model A era through 1948 and likely longer.
Old 05-09-2026, 08:33 AM   #24
Gary WA
Gary WA's Avatar
I agree 100 percent!!
www.whidbeymodelaclub.com
