Old 03-23-2026, 12:32 PM   #21
glennpm
glennpm's Avatar
Default Re: 39 Torque tube non standard bearing race
Originally Posted by 19Fordy View Post
Glenn, Thanks for the arrow.
... and thanks Jim for your sketch :-)
Old 03-23-2026, 01:04 PM   #22
Tubby
Thanks to all who have responded here
Tubby is offline   Reply With Quote
Old 03-23-2026, 02:20 PM   #23
glennpm
glennpm's Avatar
You're welcome.
The key is to heat the area around the torque tube race and seal locations. Stand the TT up on the bell end, heat it up and use a long bar, in my case I used an axle shaft from the TT flanged end, and they should come out easily.
https://www.fordbarn.com/forum/showt...ue%2Atube+seal
I like to use an electric heat gun and heat it up for several minutes. You're looking for 300°F approximately.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 03-25-2026, 08:54 AM   #24
Bored&Stroked
Bored&Stroked's Avatar
I didn't have the magical tool to spin the split one out on my 32, so I used a die-grinder and carefully cut through the old race (all the way down the length of it) and took it out.
