Old 03-05-2026, 08:26 AM   #21
flatford8
flatford8's Avatar
Default Re: 49-53 mercury rods
Delete
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 03-05-2026, 09:19 AM   #22
L-head
If you have a Merc crank is sized and uses the early rods, I would carry it to a machine shop and have the stroke verified. If it has the early rod size jornals it has been "stroked," your 4" pistons will not work in that combinaton.
L-head is offline   Reply With Quote
Old 03-05-2026, 09:33 AM   #23
matthewejacob
yeah i think i'm going to just buy a more compatible crank from scat. when i baught it I didn't know all this about how guys used to grind them down to get a longer stroke. I'd rather have the later rods in it than mess with the floating bearings. i listed it on marketplace but around here there doesn't seem to be a lot of interest in the flathead stuff. I had a spare complete engine i had sitting around in case i needed it, listed it for i think just under 100 bucks. had maybe one question about it and it's still sitting in the shop. but you never know.
matthewejacob is offline   Reply With Quote
Old 03-05-2026, 04:46 PM   #24
Als48
Where are you located, Matthew? There may be someone local who can help out with your decisions.
Just remember, Murphy's Law is not a suggestion!
Al H
Als48 is offline   Reply With Quote
Old 03-05-2026, 05:02 PM   #25
rotorwrench
rotorwrench's Avatar
The old floaters are better than the locked in bearings but the problem is finding a good set of floaters with steel backings. Some of the new stuff is cast bronze and they can split from each other between the two paired rods on the crank journal. A well fit set of steel backed floaters is a very good set up in my book.
Old 03-05-2026, 11:32 PM   #26
matthewejacob
I'm in proctorville OH. Funny you should say that cause I just ran into a guy today, older guy that was around when these engines were on the road. He was looking for a crank just like what I had to build an old school stroker. Wound up selling mine to him for almost what I paid and we chatted for about an hour about it. The real hangup for me was that I already had baught the Merc 4" strike pistons and I really didn't want to have to track down a new set of pistons and rods and bearings. Doing that may have cost me more than a new crank. This way my stock rods will work just fine with the pistons I have and he said those rods are pretty stout and well made. I did see eagle cranks are slightly cheaper but they only have the 2" rod journals and not the larger ones so it looks like scat it is. The only piece of the puzzle I don't have yet is the cam. I was going to out a mild cam in it but I've also read that by 53 Ford had pretty well had them figured out and a lot of guys are pretty happy with the stock cam. For me, it would really be just because I like that lumpy sound. It wouldn't be great for cruising though. And this isn't a race truck. I'm just trying to wake it up a little.
