#21 | |
#22 |
The threaded nipple fits an FL-820-S filter, It is too large to fit the FL-1A filter
(I tried both filters) The nipple will not fit the 90 degree adapter it came with. I tried both ends. The filter pictured is a Purolator equivalent to the FL-820-S. Besides I think the adapter would hold the filter too close to the block and interfere with the oil drain back tube. |
#23 |
#24 |
Randall. (https://youtu.be/9YXjaxxC7rE?si=3hjP2ezEiBit84gL) that is a good test video.
i am surprised that the gallery baffle at #1 cyl. was modified by ford in 1928. it was raised by about 5/16" to the height of the lifter boss, aswell the timing housing opening baffle was lowered. it doesn't seam like a lot of oil going into the rear sections of the gallery. i suppose that on the first blocks too much oil was directed rearward because the pump delivers lots of oil. i don't know but maybe not enough lube to the camgears?
old ugly my mom would have told me. "these things are here to test us" |
