Old 01-08-2026, 10:39 AM   #21
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Holley 94 Rebuild - Secondary Carb
Originally Posted by Ziggster View Post
Going with progressive linkage. My Edmunds intake is rearwards biased on account that I’m keeping the stk generator in its stk location. The forward carb is in the exact same position as one on a single carb intake. As such, I want to run that carb only all the time and the secondary will open when primary carb is 65% open. This makes engineering sense to me at least as an engineer. lol!
Good luck !
Ken/Alabama is offline   Reply With Quote
Old 01-08-2026, 10:40 AM   #22
Ziggster
The Edmund intake.
Ziggster is offline   Reply With Quote
Old 01-08-2026, 11:27 AM   #23
petehoovie
petehoovie's Avatar
The Edmund intake.
Old 01-08-2026, 01:21 PM   #24
Ziggster
Originally Posted by KiWinUS View Post
Exactly. Hope it’s an open plenum intake (which most Edmunds aren’t) or it’s going to idle on 4 cylinders.
I mapped out the runners of the Edmunds intake. It was a month or two ago, and IIRC, it was an “open” intake, but your comment caught my attention. Geeze! Here’s a coloured coded diagram of the runners from each carb throat/opening. Let me know what you think. I’m on the road so can’t do much checking.
Old 01-08-2026, 03:22 PM   #25
petehoovie
petehoovie's Avatar
Old 01-08-2026, 07:13 PM   #26
Ziggster
Doing a little digging into throttle plates and discovered they’re not round. lol! Another rabbit hole. Just trying to understand how I can get a better seal between the throttle plate and body/throat. Interesting tech info in this link. Not sure how accurate the info is, but still interesting. Will measure both the old and new throttle plates tomorrow.
https://www.xs650.com/threads/the-my...numbers.43752/
Old 01-08-2026, 07:21 PM   #27
Ziggster
With the new plates installed in the base and comparing that with the untouched stk base with stk throttle plates, when closed, the angle of the plates are very different between the new and old plates. The base with the new plates has a steeper angle when closed compared to the stk setup (distance between arrows). Not sure why that is, and not sure if that is good, bad or ugly. Was hoping with all the new parts it was just going to be a simple “rebuild”. Haha!
Old 01-08-2026, 09:17 PM   #28
1952henry
1952henry's Avatar
Speedway does, or did sell throttle plates for secondary carbs. They have a different bevel than stock.
A trick to sealing the plates is to get some GM DAG 213 sealant for throttle plates. Paint it around closed throttle plates, wait for it to set, then pop open plates. My understanding is this was done at the factory on the tripower setups.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 01-09-2026, 12:55 AM   #29
petehoovie
petehoovie's Avatar
Old 01-09-2026, 01:14 AM   #30
Ernstudet22
Your carb body looks really nice. Are the pics before or after the clear?
Ernstudet22 is offline   Reply With Quote
Old 01-09-2026, 01:17 AM   #31
Ernstudet22
Would you share contact information for vintage speed?
Old 01-09-2026, 01:47 AM   #32
tubman
tubman's Avatar
Be careful of what you ask for.
Old 01-09-2026, 05:00 AM   #33
Ziggster
After the clear.
Old 01-09-2026, 05:03 AM   #34
Ziggster
Link to their site.
https://www.vintagespeed.com/aboutus/
Screen shot of same.
Charlie Pride.
Old 01-09-2026, 05:12 AM   #35
Ziggster
Went back and checked their catalogue info on those throttle plates, and indeed the bevel angle on the edge is 12 degrees vs the 5 degrees for the stk ones. So, that at least would explain the difference in the angles when closed. Will try to speak with Charlie today or on Monday.
Old 01-09-2026, 05:18 AM   #36
Ziggster
Thanks for sharing. I had forgotten about that product as someone had mentioned it my HAMB thread on dual carbs (link below). I even found a vendor it. Believe it was around $20. Will order some for sure. Thanks for the reminder. Haha!
https://www.jalopyjournal.com/forum/...1343799/page-2
Old 01-09-2026, 07:40 AM   #37
Ziggster
After much fiddling, decided for now, to go with these two stk plates that I gave a quick cleaning with some sponge sanding blocks. Not sure of the grit of each, but guessing maybe 180 and 220.
It’s not as good as the remaining stk base in terms of sealing, but when trying to blow through each throat, there is a lot of resistance compared to the new aluminum 12 degree plates. The bottom plate in the pic seals a bit better than the top plate.
I have some Permatex bearing sleeve retaining liquid, and wonder if a coat of that might help. Will look into that separately. Now to continue with the rebuild.
Old 01-09-2026, 07:42 AM   #38
Ziggster
Will have to come up with a washer of some sort for the end of the shaft. Not got to remove a stk linage from a stk shaft as there is no need for that linkage.
Old 01-09-2026, 07:44 AM   #39
Ziggster
Pic of base with plates installed showing length of new extended shaft. Not sure if I’ll need that much.
Old 01-09-2026, 08:58 AM   #40
Ziggster
Went to install the new hex head idle mixture screws with the new springs. Both were hard to install. One in particular was really bad. Checked and then noticed there were practically no threads left in that one bore. Re-tapped both, and new screws installed easily.
