Old 01-01-2026, 06:49 PM   #21
Keith True
Keith True's Avatar
Default Re: Adjusting the flywheel housing
He's talking about the bolts that attach the housing to the engine block.There are actually six,if you add in the two that hold the throttle linkage over the top.The ones prone to cracking are the lower two on the rear of the block.
Keith True is offline   Reply With Quote
Old 01-01-2026, 06:58 PM   #22
alexiskai
alexiskai's Avatar
OK that makes more sense. That’s where I’ve seen housings cracked.
