Old 11-24-2025, 11:35 AM   #21
petehoovie
petehoovie's Avatar
Default Re: 6 volt Generator brushes squeal like a pig!
Originally Posted by ndnchf View Post
It just so happens that I was sanding in model A generator brushes this morning using a KR Wilson brush sander. It makes the job quick and easy. Itook a few photos.
Old 11-24-2025, 01:08 PM   #22
Bill OH
Grdpa stopped the noise with a drop of kerosene on the brushes.
Bill OH is offline   Reply With Quote
Old 11-26-2025, 06:06 PM   #23
Flathead Fever
Flathead Fever's Avatar
Maybe the generator is hungry. I had a pig that was squealing like your generator. I went to feed it, but I was out of its favorite food. It looked at the food I had set down, then it looked up at me again, then it stuck its head between my legs and threw me about four feet straight up and then proceeded to ram me with its serrated tusks all the way across its cage. Tore my pants and legs all up. It kicked the crap out of me, and he was supposed to be a pet. I found him in the yard when he was a baby.
I'd try feeding your generator a different brand of brushes. You might disconnect the main charging wire from the generator to see if it still squeals, maybe pull the brushes back and start it to see if it still squeals to make sure it's not something else inside that rubbing on something.
Flathead Fever is offline   Reply With Quote
Old 11-27-2025, 06:37 PM   #24
koates
It is a definite NO-NO to put any type of lubrication on the commutator or brushes which must be always clean and dry. NO LUBRICATION. Regards, Kevin.
koates is offline   Reply With Quote
