Old 10-13-2025, 02:30 PM   #21
Kube
Super Moderator
Kube's Avatar
Default Re: Hammered alxe shafts - repairable?
Greg, I'd just sent you a private message.
By the way, welcome to the Barn
Old 10-13-2025, 02:53 PM   #22
UpNorthGreg
Thanks Kube. I tried to pm you back, but I don't have enough posts.
UpNorthGreg is offline   Reply With Quote
Old 10-13-2025, 03:00 PM   #23
deuce_roadster
deuce_roadster's Avatar
There is only 1 way to correctly fix this and that is to replace both axles with ones that are either new or used ones that have passed aircraft quality crack detection. By bending the end back, you are betting that you won't lose 1 or both rear wheels while driving because if you lose the threads and nut, you will lose the brake drum and wheel/tire combo.
Old 10-13-2025, 03:05 PM   #24
tubman
tubman's Avatar
If you are going to try and straighten them, at least add those clips that bolt on to the backing plates to keep the wheel in place in case of a broken axle. (I'd prefer "Safety Hubs" if I knew where to get them.) https://www.speedwaymotors.com/Early...xoCbncQAvD_BwE.
If they survive a re-torquing and you have these, you might be OK.
Old 10-13-2025, 03:19 PM   #25
UpNorthGreg
Axles will be replaced.
Back when I was a kid, Corncrib mechanics was all we knew. Growing up in farm country we had more time and tools than we had money and knowledge. Surprised we survived.
Old 10-13-2025, 03:21 PM   #26
Kube
Super Moderator
Kube's Avatar
Only need five more Yes?
Old 10-13-2025, 03:22 PM   #27
Kube
Super Moderator
Kube's Avatar
Those actually work. Or, at least I witnessed them working one time on a friend's '48 coupe.
Old 10-13-2025, 04:04 PM   #28
Ggmac
Make sure you have the original 41 rear . One of my 41s had a 46-48 rear in it , which takes different axles . The 41 is easy to distinguish, it has 2 holes where the spring shackle goes .
Ggmac is offline   Reply With Quote
Old 10-13-2025, 05:52 PM   #29
hueyhoolihan
...may know what you're talking about. i think they were on the car i own when i purchased it and needed to come off to remove the hub/brake drum. they mount using a couple of the wheel cylinder mounting holes in the backing plates. ...look look like a good idea and resemble a disk brake caliper...but without pads or pistons.
hueyhoolihan is offline   Reply With Quote
Old 10-14-2025, 05:18 AM   #30
glennpm
glennpm's Avatar
Brake drum retainer
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 10-14-2025, 08:10 AM   #31
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
Having lost the rear wheel off our '65 Mustang on the Golden Gate Bridge many years ago at speed (during rush hour) I can assure you it is a very scary and unpleasant experience. Replace the axles.
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 10-14-2025, 09:07 AM   #32
tetanus
There's a couple salvage yards that specialize in the old stuff about 100 miles from me. I checked and between the two there's a half dozen '41 rear ends to choose from at $400 each. So, worse case, I can grab a whole rear end if I have too. The rear end I have has already been blasted, primed, and painted, so finding just axles would be preferred.
Where is this honey hole with all these ford parts located?
tetanus is offline   Reply With Quote
Old 10-14-2025, 09:49 AM   #33
ford38v8
ford38v8's Avatar
Wherever he’s at, I know for a fact that you have at least as many in your own state of Wisconsin!
Alan
Old 10-14-2025, 09:59 AM   #34
UpNorthGreg
Look up French Lake Auto Parts and Windy Hill Auto Parts. If you go to car-part(dot)com you can search salvage yards across the country.
Old 10-14-2025, 10:46 AM   #35
Lanny
Lanny's Avatar
French Lake has always been a great place for old car parts, Windy Hill
was fairly well picked over for early Ford parts the last time I was there.
Rohners Auto Parts, 800-622-0290, is one of the largest salvage yards
in sw. MN., and is about 7 miles north of Willmar, MN.
They still have quite a few Old cars in the yard, but may be picked over
for Old Ford parts, call them at 320-235-4602.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 10-14-2025, 10:58 AM   #36
ford38v8
ford38v8's Avatar
Chigger country.
Alan
Old 10-14-2025, 01:35 PM   #37
Kube
Super Moderator
Kube's Avatar
Greg, I have mint axles, and I am betting that Fred at Southside Obsolete (MN.) may very well have NOS.
Old 10-14-2025, 03:16 PM   #38
my4dv8
Think Kenny Rogers “ you picked a fine time to leave me loose wheel “
my4dv8 is offline   Reply With Quote
Old 10-14-2025, 03:38 PM   #39
UpNorthGreg
I emailed Fred, he said he'd check. I'll keep you in mind for the axles. Going to check on something on Thursday. Might be hauling home an entire car if everything looks good.
