Old 10-02-2025, 07:18 PM   #21
40-A Twins
40-A Twins's Avatar
Default Re: I need a Project
Redesign transmission gears so the car can reach 30-35 mph in second gear.
Astra-Werke demonstrated this
https://www.youtube.com/watch?v=RmQjirT_640
40-A Twins is offline   Reply With Quote
Old 10-02-2025, 08:07 PM   #22
30Murray
Front spindles
30Murray is offline   Reply With Quote
Old 10-02-2025, 08:12 PM   #23
ModelA29
ModelA29's Avatar
Leakless pumps already available. Different piston - why? less mass, faster reving? C'mon it's a Model A.
Steering box maybe new castings that take repro parts but which one 2 or 7 tooth. Mine has a Randy Gross F100 box it's great but the A purists don't like it.
Automatic trans - already been done and not a big market
Syncro trans - already done. Maybe a rebuild kit for ones own trans with syncro gears but you may have trouble if Mitchell had patented his. OD already done and there is no room in the A case to make it an OD 4 speed ala F150 TOD.
Casting new block for A internals - a step backwards and doesn't meet the race rules V4 and V4F require pre 1935 production block and severely limits mods that can be made to it. again small market.
Bigger carb a Model A looking Zenith that outflows the Model B carb may be the perfect addition for a stock looking Burtz whose performance is choked by the stock carb. Might also be paired with a stock looking intake with larger passages.
ModelA29 is offline   Reply With Quote
Old 10-02-2025, 08:51 PM   #24
alexiskai
alexiskai's Avatar
Lotta guys asking for things that already exist, already exist but they want it to match the OEM appearance, or are physically impossible.
Old 10-03-2025, 05:01 AM   #25
Bruce of MN
Bruce of MN's Avatar
Hey, there's no rules in wishing! Remember how many Farah Fawcett posters got sold?
Besides, we have great faith in Terry.
Bruce of MN is offline   Reply With Quote
Old 10-03-2025, 12:29 PM   #26
Chris Haynes
Chris Haynes's Avatar
Originally Posted by Jim/GA View Post
Terry, please look into building a New Model A Steering Gear Box that is patterned off of the F-100 box with the rolling sector gear element, or it could be the "recirculating ball" design used in the 1950s.
Due to shortage of F100 steering boxes Randy Gross is now working on an all new replacement. I held one of the castings in my hand last week and it looked great. I don't know what the internals will be but with Randy you know they will be great.
I bought a new steering box for my '32 from Neil's Hot Rod Parts. 18 to 1 ratio and it bolts in.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 10-03-2025, 12:40 PM   #27
Chris Haynes
Originally Posted by Bob Bidonde View Post
As I become senior, it gets difficult to shift gears in my Model A's. How about designing an efficient automatic transmission with overdrive that is a bolt-in for the Model A.
I am 80 and have no problem shifting. It's all in the ear. I only use the clutch for starting and stopping. Not for shifting.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 10-03-2025, 12:43 PM   #28
Chris Haynes
Originally Posted by BRENT in 10-uh-C View Post
Terry, with as much tooling, fixtures, patterns, etc. from your present 5 main block, what is the feasibility of creating a replacement block that accepts a stock Ford A crankshaft? This market would be for the individual that maybe has need for just a replacement block (-due to thin castings, cracks, etc.) or for the vintage racer that must run a stock-type block.
Isn't Todd already casting these?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 10-03-2025, 01:29 PM   #29
Mel Gross
To All;
We are now in the final stage of having new F100 steering boxes for Model A's.
They will look and function exactly the same as the original F100 steering boxes that we have been doing for close to 30 years now.
We also have plenty of cores and continue to buy cores so are plan is for us and our products to be around for a long time.
Thanks
Randy Gross
714-292-8660
[email protected]
Mel Gross is offline   Reply With Quote
Old 10-03-2025, 03:12 PM   #30
Flathead
Flathead's Avatar
Originally Posted by Mel Gross View Post
To All;
Thanks
Randy Gross
714-292-8660
[email protected]
Thank you Randy!
Let's all support this effort.
Flathead is offline   Reply With Quote
Old 10-03-2025, 03:27 PM   #31
BlueSunoco
Originally Posted by Lawrie View Post
what about building a new flathead V8, maybe a copy of a 59A block,
Im sure it won't take up much time.
Lawrie
Yeah Daddy
There has to be a pretty good market out there for replacement Flat head V-8 blocks the 59AB would be my choice...
And/or as Brent Terry said, maybe even a bone stock three bearing Model A Ford block I can see that one too.
BlueSunoco is offline   Reply With Quote
Old 10-03-2025, 05:30 PM   #32
Flathead
Flathead's Avatar
A V8 block would unfortunately be a nightmare to produce.
My dream would be an A block with improved B-style intake ports and use the B crank. That would solve the weak bottom end issues and somewhat resemble what you have already done. Ford finally got it right with the B but it was too late.
Old 10-03-2025, 09:13 PM   #33
Steve28
How about a two up and two down five main crankshaft
Steve28 is offline   Reply With Quote
Old 10-03-2025, 11:28 PM   #34
Dodge
How about a vibration damper?
Dodge is offline   Reply With Quote
Old 10-03-2025, 11:36 PM   #35
johnneilson
I have one made from billet
You need the cam also
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 10-04-2025, 05:20 AM   #36
David in San Antonio
David in San Antonio's Avatar
I wonder about a vibration damper as well.
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 10-04-2025, 06:03 PM   #37
Synchro909
Synchro909's Avatar
Vibration dampers are already available - from New Zealand. As has been observed, many of the thigs wished for are already available if you look in the right places.
Terry will decide what is the best one to do.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 10-04-2025, 08:24 PM   #38
rmnly
Cast iron high compression head for Model T. Only ones out there are aluminum.
rmnly is offline   Reply With Quote
Old 10-04-2025, 10:09 PM   #39
JayJay
Synchro - I’ve tried to source these dampers without luck. Do you have a current source?
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 10-05-2025, 09:20 AM   #40
Richard Knight
I am in the new steering box camp.1937 is the first year for recirculating ball steering in a Ford. I was shocked at how easy the steering was when I drove a 37.
Richard Knight is offline   Reply With Quote
