Old 09-30-2025, 01:00 AM   #21
deuce lover
deuce lover's Avatar
Default Re: “Correct” fan belt doesn’t fit
As 35fordtn stated,you need to source one.You might start by taking a circumference measurements (with gen at bottom of intake and at the top) at the pulleys edge . From that you can find the belt that will work.
Here is a chart that might help.Disregard what I circled in blue,that was for my application,36 engine in a '33.Took me 3 attempts to get it right because I used an alternator conversion.
deuce lover is offline   Reply With Quote
Old 09-30-2025, 01:11 AM   #22
petehoovie
petehoovie's Avatar
Originally Posted by deuce lover View Post
As 35fordtn stated,you need to source one.You might start by taking a circumference measurement at the pulleys edge . From that you can find the belt that will work.
Old 09-30-2025, 03:01 AM   #23
Mart
Mart's Avatar
The table above shows a good bit of info. That for a B series belt, the belt number is 3 less than the circumference. So measure the circumference around the outside of the pulleys and subtract 3. That will give you a belt size. B denoted the profile. A Ford will take a B type belt.
You can get B series belts from Industrial bearing supply places and ebay. You don't need an automotive supplier.
Mart.
Old 09-30-2025, 02:13 PM   #24
alchemy
alchemy's Avatar
With the generator up higher, will the fan clear the radiator? I’m not fully familiar with 37’s.
alchemy is offline   Reply With Quote
Old 09-30-2025, 02:26 PM   #25
glennpm
glennpm's Avatar
With your engine exposed like this you can pretty easily figure out the belt length that you need.
- Make a mark on your crank pulley and the belt in the straight down position
- Hold the belt in place there
- Pull the belt over the generator pulley, straight up position and make another mark
- Take the belt off, measure between your marks and double the value
- Look for the next longer belt but shoot for around maybe 1" or 1-1/2" longer
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 09-30-2025, 03:04 PM   #26
rockfla
rockfla's Avatar
AND paint it back Ford Green IF you so desire
Old 09-30-2025, 03:54 PM   #27
Mart
Mart's Avatar
This is a good recommendation. Get the dimension described. Double it. Add an inch. Then deduct 3 and order a B series belt that length.
Example: Described dimension (belt wrapped around one side, from bottom of crank pulley to top of generator pulley) lets say it's 28".
Double it. 56" add one. 57".
Deduct 3 to get belt number (based on info in table) Belt required is a B54. Should be easily available.
Trial and error might then dictate whether it is right. You might need a B53 or B55. Half inch sizes are also available but can be more expensive and harder to find.
I used to get belts locally but have to order them off ebay now. Very easy to get what you need.
Mart.
Old 09-30-2025, 05:13 PM   #28
azlkk
azlkk's Avatar
Nah, it was blue when I took it out. Expected green but cleaning off 60-70 years hid the blue. Probably due to it being an OEM dealer replacement engine.
'35 5 Window Deluxe Coupe w/radio- wife's uncle purchased new
azlkk is offline   Reply With Quote
Old 09-30-2025, 05:38 PM   #29
petehoovie
petehoovie's Avatar
Old 10-01-2025, 05:35 AM   #30
38 coupe
38 coupe's Avatar
Be careful when tightening your generator up to adjust belt tension. The first picture shows the generator not lined up with the slot in the intake. You can easily break the edges off the slot on the front of the intake if the generator is not lined up. Both cast aluminum and cast iron intakes will break, the aluminum ones are slightly more prone to breaking.
Old 10-05-2025, 05:45 AM   #31
Mac VP
Mac VP's Avatar
Between 1933 and 1953 flathead V-8’s (of the 85-100 hp variety) there were a total of three “long” belts used by Ford. We stock all three types of. When the customer calls for a belt, I always ask them “is your engine application stock or modified?”
Most times they’ll reply that it’s stock. I match that up to the correct belt and ship it out. Half the time they call later after receiving the belt and state that it doesn’t fit. All we can do is to take it back and issue credit.
Other times they’ll respond that the application is not stock….they’re running an aftermarket alternator. Due to the smaller pulley on these, none of the standard Ford belts are going to fit properly. We back off suggesting one of our belts.
This thread is further proof that other modifications (often unknown to the customer) will confound the buyer when trying to replace a belt. The suggestions for sizing a belt application are good advice.
And this is why I don’t love selling belts…….
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 10-05-2025, 03:44 PM   #32
Elmo Rodge
Elmo Rodge's Avatar
Just a thought but if a few people would measure the overall diameter of their pulleys and the center to center distances of the two and what belt they are using we might have a good starting place.
Wayno
Life is not a spectator sport.
Elmo Rodge is offline   Reply With Quote
Old 10-05-2025, 06:06 PM   #33
azlkk
azlkk's Avatar
The earlier pumps in the heads belt fits nicely. Now I just need to find someone in Phoenix that needs a new ‘37+ one to donate to.
