Old 07-15-2025, 02:04 AM   #21
deuce lover
deuce lover's Avatar
Default Re: '40 rear fender rub one side only
Thanks for posting the pics.The arch of that rear brace could be different than the other side.Putting a 1/2 spacer on the body side ? To me your wheels are to wide (can you determine the width & setback?) ,Street Rod look ? No sure if a next size down tire would be much different, Than the cost ?
deuce lover is offline   Reply With Quote
Old 07-15-2025, 05:21 AM   #22
Mart
Mart's Avatar
Pull the fender and brace out a little bit to make more clearance.
You have a few things that are making things worse for you.
1, oversize wheels.
2, oversize tires.
3, overlong shackles.
4, possibly other mods to lower the car. (flatter spring, leaves removed perhaps.)
It's not surprising you have clearance issues. The overlong shackles will allow more side to side movement on the axle during cornering.
Once you go to a modified condition you are left to your own devices. You could pull the rear of the fender out but the front will go in. What is the clearance like there?
You need to use your own judgement how to gain the clearance you want.
If it is experience you lack, there may be someone local that can cast an eye over it and offer advice/help.
Old 07-15-2025, 05:47 AM   #23
38 coupe
38 coupe's Avatar
Your tire size indicates a 17 inch wheel. Changing wheel sizes needs to be done carefully to avoid tires hitting things. Your wheels may have the wrong back spacing. I'm not a lot of help when it comes to aftermarket wheels, I use the ones Ford made for my cars and have no problems with tire to fender rubbing.
Old 07-15-2025, 08:46 AM   #24
19Fordy
19Fordy's Avatar
Many years ago I had the same tire clearance problem and found it to be an easy fix. Body fender work had been done on the fender years before.
At some point in its life that fender was probably worked on with a hammer and dolly causing it to loose its exact OEM contour.
Remove the lower rear fender brace bolt and you will find that the lower rear part of the fender is very flexible and can easily be pulled out by hand a little to provide more tire clearance. This won't damage the fender. Then modify the fender brace to fit and reinstall or install a spacer between the fender brace and the frame rail.
Old 07-15-2025, 10:42 AM   #25
petehoovie
petehoovie's Avatar
Old 07-15-2025, 12:21 PM   #26
19Fordy
19Fordy's Avatar
Thanks Pete. Big difference.
Old 07-15-2025, 01:15 PM   #27
alchemy
alchemy's Avatar
Undo the bolt between the curved brace and the frame. Get a slightly longer bolt. Then try stacking some washers between the brace and the frame. One at a time until the side of the fender looks plumb. Any more than that and you’ll have to switch your wheels.
alchemy is offline   Reply With Quote
Old 08-04-2025, 08:19 PM   #28
IanFarrell
So, just an update (and another Thank You!).
I was able to procure some used, but good enough, 215/55/R17 tires and got those mounted. Of course, the problem went away. I'd prefer something a bit bigger, but this was the cheapest, easiest way to get the car to the point where I could do test drives while working and joy rides around town!
IanFarrell is offline   Reply With Quote
Old 08-04-2025, 08:32 PM   #29
TJ
TJ's Avatar
I would use a 235X75X15 series tire and the 15 inch wheel, it's narrower and taller than what you have now. In my avatar that is what I have on my 40 and no rubbing.
Old 08-04-2025, 09:11 PM   #30
tubman
tubman's Avatar
I am glad the O/P solved his problem on his own.
However, I don't think this forum was ever intended to help folks put 55 series 17" tires on '40 Fords. I think "TJ" did it right by simply stating what he should have done.
I know some of you folks want to expand the number of younger people in the hobby, but at what price?
