Old 06-29-2025, 08:08 PM   #21
ford38v8
ford38v8's Avatar
Default Re: My new project. And introduction.
Originally Posted by AZMerc39 View Post
I will keep it as original as possible while making is usable for todays world. I saw one of these 39 sedans with way more done to it than i want to do to mine still go for $20,000. That was 350 SBC swap, positrac rear end, different steering column and wheel, two piece front seats, etc.
I just want modern day usability since i do not plan to make it a weekend only car. They are meant to be driven, and that's what i want to do. But the world is vastly different than almost 90 years ago.
Ken, Yes, I agree with your need of air conditioning in Arizona, so I guess it's a SBC in the works for you. That's the easiest way to get where you need to be.
Something else did catch my eye, though, something that most rodders never consider... you mentioned two piece seats? I take that to mean buckets? Don't for a minute think that any seat replacement could be anywhere near as comfortable as your stock Ford/Mercury seats of the era. Think twice before replacing your armchair luxury.
Alan
Old 06-29-2025, 08:55 PM   #22
Clem Clement
Clem Clement's Avatar
[email protected]
Keith Lee
Keith makes great reproductions of knobs/steering wheels/horn button/etc. He made a '40 MERC button spare
for my car.
My son has my ' 40 4door convertible now. Love the car. Do you have the air heater? They are being reproduced now.
Clem
Clem Clement is offline   Reply With Quote
Old 06-29-2025, 11:21 PM   #23
AZMerc39
AZMerc39's Avatar
Im going to keep a Flathead in it. Im just saying thats what i saw. I will see of I can find it again. They were still larger seats, but not racing bucket seats
That's a fantastic question, can you ask me a different one?
AZMerc39 is offline   Reply With Quote
Old 06-29-2025, 11:21 PM   #24
AZMerc39
AZMerc39's Avatar
Originally Posted by Clem Clement View Post
[email protected]
Keith Lee
for my car.
Clem
excellent, thank you! Mine is a bit damaged
Old 06-30-2025, 01:27 AM   #25
AZMerc39
AZMerc39's Avatar
Oops, it was a coup, not a sedan. But it actually went for $40k.
https://bringatrailer.com/listing/19...-coupe-custom/
Old 06-30-2025, 12:15 PM   #26
mfirth
I saw a picture of a 40s Mercury once with a small a/c unit mounted on an 8BA/8CM engine once, don't remember where. The engine had a small 4 barrel carburetor & aluminum heads. Just saying; someone's done it.
mfirth is offline   Reply With Quote
Old 06-30-2025, 12:43 PM   #27
AZMerc39
AZMerc39's Avatar
I know i saw some adapters for a compressor on speedway. But the Radiator is the bigger issue. I found some with condensers but not with the correct ports. So i am on the lookout for those still.
Old 06-30-2025, 01:10 PM   #28
glennpm
glennpm's Avatar
https://vintageair.com/ford-1937-194...mount-bracket/
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 06-30-2025, 01:17 PM   #29
glennpm
glennpm's Avatar
https://www.fordbarn.com/forum/showp...4&postcount=14
Default Re: air conditioning on a flathead?
I put A/C on my 40 Ford more than 10 years ago. I have driven anywhere I desired without engine overheating regardless of the terrain or temperature. That includes over the Rocky Mountains, in August, to Bonneville from southern Georgia. That trip was with STOCK Ford waterpumps and STOCK Ford radiator. I installed a blow-through electric fan on the condenser to help the exchange rate at low speeds to provide cold air from the A/C. The fan is not used at highway speed and it is a restriction to maximum air flow. But, still NO OVERHEATING. I have since changed to a Walker radiator with their condenser because the stock radiator braces repeatedly broke loose from the top tank. I think the extra weight of the condenser and blow-through fan contributed to the breakage. I still have the stock waterpumps in place. I suggest the Walker radiator with their condenser because the recovery rate of the radiator is superior and the condenser is a nice arrangement. I built my brackets and special reinforcement gadget at the front of my aluminum intake manifold. These days there are brackets advertised in magazines(as noted above) and they should work OK. I would only add that some aluminum intake manifolds are not well designed at the generator mount so they might not handle the additional loading. The Edmunds on my car was one such example.
Old 06-30-2025, 02:54 PM   #30
AZMerc39
AZMerc39's Avatar
Thank you. Im going to have to try to find out which he used.
Old 07-04-2025, 12:53 PM   #31
38 coupe
38 coupe's Avatar
About a decade ago one of the local car club members in Houston restored a 41 Mercury sedan and added air conditioning using the Vintage Air mounting kit. The engine ran hot. He found he had to make brackets and move the condenser forward of the radiator, towards the grill. After moving the condenser everything was good. He sold the car after his wife quit riding with him on tours.
The car is now owned by friends of mine in central Texas, the wife drives the car daily to work even in the summer.
The point is you can have a mostly stock Mercury that runs on pump gas, goes reasonably fast (65 with stock gearing, 80+ with overdrive), and has air conditioning. As everyone above has said, you need to plan ahead, but it is worth it when everything works out.
Old 07-05-2025, 08:05 PM   #32
TomC750
TomC750's Avatar
There was a '52 or so Ford pickup at Springfield - flathead with air. Did not look at setup close. I was likely getting too hot at the time with temp in the high 90's.
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
Old 07-05-2025, 09:21 PM   #33
Clem Clement
Knob Soup [email protected] Lee https://www.youtube.com/watch?v=IESeHql
Keith does great work on knobs and horn buttons and steering wheels
Clem
Old 07-07-2025, 11:18 AM   #34
Brendan
Brendan's Avatar
i cant understand why people put in a diffrent seat in any old car, the ones they put in look very uncomfertable, and puts you into a weird position
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 07-08-2025, 06:19 PM   #35
AZMerc39
AZMerc39's Avatar
It will be worth it to be able to drive in our summers here. I want to keep it mostly stock, but modern/daily usability is the goal. I have no idea if i have O/D or not. I will also need to upgrade the brakes, since it appears that i only have mechanical brakes. Someone up the road opted for the heater, but not the good brakes. I should also look to see if they came with any sort of insulation under the carpet, and headliner. If not, add some.
Old 07-08-2025, 06:20 PM   #36
AZMerc39
AZMerc39's Avatar
Dont blame ya. Heat can be brutal.
Old 07-08-2025, 06:20 PM   #37
AZMerc39
AZMerc39's Avatar
Clem
Thank you!
Old 07-08-2025, 06:22 PM   #38
AZMerc39
AZMerc39's Avatar
Me either. I love these stock seats.
Old 07-08-2025, 06:29 PM   #39
tubman
tubman's Avatar
Every '39 Merc (or Ford for that matter) I've ever seen has hydraulic brakes. What makes you think you have mechanical brakes?
Old 07-08-2025, 08:52 PM   #40
AZMerc39
AZMerc39's Avatar
Well, you see, I'm a bit of an idiot. I thought that because the res isn't where i'm used to them being. After doing to more research, it seems like its under the car somewhere? Unfortunately, the car isn't parked at my house due to a multitude of reasons, so I'm unable to crawl around it whenever i want. So i didnt see it on the firewall, so i assumed it wasnt there.
The second reason is when looking at rebuild kits for wheel bearings and seals, there were kits under the '39-40 Merc section that were optioned for mechanical brakes and hydro brakes.
