Old 05-22-2025, 09:10 AM   #21
katy
katy's Avatar
Default Re: Cause for oversteering
Originally Posted by Keith View Post
I have completely rebuilt the front end
Was the axle checked for straightness and camber angle?
Are the spring perches tight in the axle?
Old 05-22-2025, 11:38 AM   #22
Big hammer
Over steer does alignment influence oversteer? My A is quick to oversteer. The toe in is about 1/16”
About 1/16 “ ? How was this measurement done ? Tow should e measured 6-8 inches above the ground, the tool to measure has pendant chains that set the height above the ground, check the Ford service bulletins
get a bigger hammer tap done
