Old 05-05-2025, 03:36 PM   #21
Robert/Texas
Robert/Texas's Avatar
Default Re: '33 vs '34 Fords
My 1934 roadster has an early January 1934 serial number which shows on the driver side front frame and on the clutch housing. I bought the car in 1995 from one of the inheritors of a small, now extinct European car museum in Spring Texas.
Several of the unique things about the car are:
The serial number includes the number 40 where American made cars show 18.
The brake system is the 4 rod rear, 2 rod front type.
It has 2 latches on each hood side but the firewall sides look like they had been modified as they are a just a bit wavy when you examine them closely.
The air vent on the cowl and the front and rear bumpers are the 1933 style.
I'm not aware of any other differences but I wouldn't be surprised if there were some.
Robert/Texas is offline   Reply With Quote
Old 05-05-2025, 03:40 PM   #22
deuce lover
deuce lover's Avatar
Originally Posted by rockfla View Post
Nope, they attach differently AND the 33 has a spring loaded lid that pops open when you pull the ash tray out. Just learned about those this weekend. Here is a 33 ash tray
Here is a 34 ashtray
deuce lover is offline   Reply With Quote
Old 05-05-2025, 03:45 PM   #23
rockfla
rockfla's Avatar
Petehoovie
Side by side comparison of 33 to 34 ash trays
Old 05-05-2025, 06:18 PM   #24
petehoovie
petehoovie's Avatar
Petehoovie
Outwardly, they look the same to me. This, looking at the pictures I posted. Weren't we talking about their outward appearance?..
Old 05-05-2025, 07:02 PM   #25
DavidG
DavidG's Avatar
In an open position, they look different given that the '33 has a lid and and the '34 does not.
Old 05-05-2025, 07:44 PM   #26
Cool 33
Cool 33's Avatar
33 cowl lights are longer than 34's.
Cool 33 is offline   Reply With Quote
Old 05-05-2025, 08:46 PM   #27
Cool Kat with Hot Car
Cool Kat with Hot Car's Avatar
As far as perceived favor, many of the hot rodders of the 40s through early 60s converted 33s to 34s by changing hoods and grilles as they thought they looked better. Same with 35 and 36 roadsters, the 36 being considered much more desirable.
Cool Kat with Hot Car is offline   Reply With Quote
Old 05-06-2025, 12:31 AM   #28
DavidG
DavidG's Avatar
While well short of a statistically valid sample, which would be about 20,000 cowl lamps, of the dozens of both years' cowl lamps that I have had there has been no consistent difference in the dimensions of their housings. And they all have the same part number.
Old 05-06-2025, 12:53 AM   #29
DavidG
DavidG's Avatar
Robert/Texas,
Given that Ford had only two engine plants producing V8 engines during the 1933-34 model years and that no open cars were manufactured outside of North America with the exception of some exotic drop-head coupes made in Germany, your car's engine number with a prefix of '40' means that its engine was made at the Dearborn engine plant. That plant's log cites that some '33-'34 V8 engines had a '40 prefix but were still in sequence numerically with those with the usual '18' prefix. Your car's body was manufactured by Murray in the States and it and the rest of the vehicle was shipped to Europe eithe completely built up (BU) or slightly 'knocked down' (SKD) or more or less completely 'knocked down' (KD) with final assembly there.
The changes to the bumpers and their brackets was not a Job#1 '34 model change, but rather a post-Job#1 running change, as were a number of other changes like the shape of the ends of the spring leaves and the shift from Champion C7 spark plugs to 7s.
The six-rod brake system was a local requirement in a fair number of European countries at that time.
Old 05-06-2025, 04:02 AM   #30
BLACKNRED
BLACKNRED's Avatar
I have a 33 5 window coupe.
after studying all sorts of things to do with the Model 40, and by no means claim to be an expert or even an authority on early Fords and in particular the Model 40.
I believe due to the lateness of the introduction in 1933, the Model 40 effectively evolved to become the 1934 version, I feel the 33 had so many issues ie grilles cracking rear wheel well cracks etc, etc
BLACKNRED is offline   Reply With Quote
Old 05-06-2025, 10:01 AM   #31
Robert/Texas
David, Thanks for your information as I am always interested in any 1934 Ford information that I can get. I should have mentioned that the body number on the firewall is 710-LB-4758 which I assume means that the car was assembled in Long Branch plant.
I was born in 1934 and owned another 1934 roadster back in the 1950’s. I sold it in 1959 about 3 months after I was discharged from the army. I wish now that I could have kept it.
Old 05-06-2025, 12:04 PM   #32
DavidG
DavidG's Avatar
All of the U.S.-made '33 and '34 passenger car with bodies not manufactured by Ford had such a body number tag on the firewall (or were supposed to have) and with the letters LB in the middle. They had no connection with Long Beach. The first group of numbers on the tag were the body type code as in your case, 710 for roadsters.
Old 05-06-2025, 10:33 PM   #33
Newc
Newc's Avatar
I've run into an issue with the third bolt [for grills] on top of the radiators. My '34's need it, but the '33 radiators lack it. ?? Newc
Old 05-07-2025, 12:26 AM   #34
deuce lover
Third bolt ? There is a plate soldered to the top of the radiator.That plate supports the grill,hood hinge bracket and the brace rods that extend to the firewall. .Here is a much better pic.
Old 05-07-2025, 01:02 AM   #35
petehoovie
petehoovie's Avatar
Old 05-07-2025, 03:01 AM   #36
Graham Freeman
1933 & 1934 radiator side straps are different at the top?
Graham Freeman is offline   Reply With Quote
Old 05-07-2025, 03:46 AM   #37
deuce lover
Not to my knowledge.He spoke about the 3rd bolt and no mention of side strap of which there is no 3rd bolt.
Old 05-07-2025, 09:54 PM   #38
Newc
Newc's Avatar
I have found the third bolt hole [and bolt] in 34 grills car/PU It is a long nut secured by those clips. Photos= Chrome PU grill and the radiator with the hole for the third bolt. The nut has a broken bolt in it. checking my core radiators about half of them have the clips for the long nut. [34's?] Newc
Old 05-07-2025, 11:01 PM   #39
petehoovie
petehoovie's Avatar
Old 05-07-2025, 11:54 PM   #40
deuce lover
It must be a truck application?
