#21 |
Here's the way I do it, hope it's helpful!https://youtu.be/8MH3HtTnshQ?si=R22y9FNARb5PhbKt
#22 |
@#$ Youtube says I am using an ad blocker - I'm not but I can't watch any of their vids any more.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
#23 |
.002" is twice what Henry intended and asking for bearings to be pounded to death. I pour babbitt and i always set them at .001" since if it's too loose it allows the crank to vibrate in the bearings, causing wear. it's best to run em tight and run em slow. if you rev the engine past 2300 on stock lead babbitt you are asking for trouble. if you got 4x nickel it can handle a bit more but best to drive em as Henry intended
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!" |
#24 |
..delete
#25 | |
#26 | |
#27 |
Methinks he's using the "tin foil" between the bearing and the cap for checking clearance, not for a shim.
#28 |
He means checking clearances with foil instead of plastigage
#29 |
Yes,tinfoil for checking,not as shims.Tinfoil is generally .001 thick.(check each piece as you use it)Some brands are thicker,or not consistant.If the crank will turn with two layers,the clearance is too much.If the crank will turn with one layer,but binds up with two,then the clearance is between .001 and .002.Turned out to be a much more accurate method of doing than I thought it would be.
