Old 02-24-2025, 11:06 PM   #21
petehoovie
petehoovie's Avatar
Default Re: 1937 Pickup Bed
Originally Posted by GB SISSON View Post
This is my deluxe '37 truck. Along with the items visible in the photo, this truck had an elongated octagonal lamp on the wiper motor cover on the passenger side. I bought it about 15 years ago, a true barn find. I got its 8ba running while still on my trailer and drove it off when I got home. When I got my sawmill I sold it to buy the 2 ton with juice brakes. It went to someone in White Center Wa, SW of Seattle. Anybody know what became of it? Seller's remorse rears it's ugly head.....One more thing, was that Anthony bed a dump, and a product of the Anthony Hoist company?
Old 02-25-2025, 12:38 AM   #22
nelsb01
nelsb01's Avatar
Where did the wire wheels come from?
1936 and 1937 had the wide five steel wheels.
nelsb01 is offline   Reply With Quote
Old 02-25-2025, 12:46 PM   #23
Westy37
Fantastic looking Pickup!!!! Never heard of the Anthony bed. I will also be painting mine a 35 color - red with black fenders and running boards. I still am unsure about mounting the bed to the frame. Are there pads for this? Wish I had taken it apart so I'd know! Also - do you have a side mount spare tire?
Westy37 is offline   Reply With Quote
Old 02-25-2025, 01:29 PM   #24
Westy37
Originally Posted by flatford8 View Post
I have a collection of parts as an on-deck project.…..hopefully it’ll resemble a ‘37 Commercial when it’s all together……..Mark
I am not sure what the rear tail light bracket supposed to look like. I have one, but not sure it is correct for the year! Do you have a good photo of one? I may need one!!!!
Old 02-25-2025, 01:31 PM   #25
Westy37
Originally Posted by v8fordman View Post
Westy, I have a 1/2 ton deluxe pickup with lots of accessories as well. Sounds as if you have all of the hard deluxe items in hand. The map light and unique wiper motor cover are extremely rare. I have an extremely rare accessory Anthony bed which turns heads. If you need any help, please feel free to reach out.
Also - could you send me or post a phot of the rear tail light and bracket. Not sure the one I have is correct????
Old 02-25-2025, 04:59 PM   #26
nelsb01
nelsb01's Avatar
See your other post for tail light bracket and license holder.
Old 02-25-2025, 05:32 PM   #27
petehoovie
petehoovie's Avatar
Old 06-11-2025, 11:08 AM   #28
Fordman7
I have 1937 Ford pickup as well and am trying to mount the bed. I have acquired wood mounting blocks but the supplier can't give me any info about where they mount. Any help in the form of pictures or word description would be helpful. The bed was just sitting on the frame when I acquired the truck so I have no reference on how to put it back.
Fordman7 is offline   Reply With Quote
Old 06-11-2025, 05:08 PM   #29
nelsb01
nelsb01's Avatar
Picture of wood blocks
Old 06-11-2025, 07:02 PM   #30
petehoovie
petehoovie's Avatar
Old 06-12-2025, 04:44 PM   #31
Fordman7
Lawson Cox I have a 1937 Ford pickup that I am in the process of redoing the bed. It was only held on by the fenders bolted to the back of the running boards when I got it and the mounting is a mystery to me. You mention wooden blocks in one of your posts but I have not found the picture you refer to when talking about those blocks. Can you post the picture so I can look at the blocks? Can you describe in any more detail about where they fit on the bed? Thanks for any help.
Old 06-12-2025, 11:08 PM   #32
nelsb01
nelsb01's Avatar
Did you miss post #29?
Old 06-16-2025, 11:07 AM   #33
New2restoring
soooo, did the 37 have a wooden bed or like superman, steel? I only ask because a gent at a car show yesterday told me steel, my recent purchase has wood?
New2restoring is offline   Reply With Quote
Old 06-16-2025, 05:47 PM   #34
nelsb01
nelsb01's Avatar
Wooden bed boards did not show up until the early 1950's
You should have a riveted steel bed with wood underneath
For clarification purposes --- the picture is of the bottom of the pickup bed
Old 06-16-2025, 06:11 PM   #35
petehoovie
petehoovie's Avatar
Old 06-17-2025, 11:13 AM   #36
Fordman7
peethovie
It looks like the blocks have the small end down to the frame but what do they attach to on the actual bed. The rear crossmember has a 3/4" flange toward the front of the bed that it might catch but that would only be catching sheet metal not any structure on the bed.
Old 06-17-2025, 11:34 AM   #37
petehoovie
petehoovie's Avatar
Originally Posted by Fordman7 View Post
peethovie
nelsb01 to respond...
Old 06-18-2025, 07:58 AM   #38
s.e.charles
s.e.charles's Avatar
Originally Posted by 1936 ford pickup View Post
. . . these pictures can help some with the pickup bed mounting.
they helped me understand the assembly; thanks
sid
s.e.charles is offline   Reply With Quote
Old 06-18-2025, 08:11 AM   #39
nelsb01
nelsb01's Avatar
The last picture (althought the end frame cross member is not attached) shows the bed bolt coming through the end of the wood block.
If you have a reproduced bed, there will be some holes you need to create.
The bolt is a tappered head bolt that has a square hole in the top of it for tightening.
If you are unclear on all of this, try and find a 1935-1937 1/2 ton pickup to reference.
One picture shows the end frame cross member attached and the hole where the bolt goes into the frame after going through the wood block.
The other picture shows the head of the bolt that you are needed.
Old 06-18-2025, 11:19 AM   #40
petehoovie
petehoovie's Avatar
