Old 03-31-2025, 07:56 PM   #21
midgetracer
midgetracer's Avatar
Default Re: Headlights 1931
I find that the connections through the plastic blocks to the headlight wiring are a poor setup at best. I suggest cutting the ends of the wiring harness off as well as the headlight pigtails and wiring them direct with the crimp on pull apart connectors. You will have to remove the resin board in the pigtail part that snaps into the bucket to get the wires through, but you will never have the contacts shorting or the poor connection that the original setup can cause.
midgetracer is offline   Reply With Quote
Old 04-01-2025, 05:17 AM   #22
benbuilder
I appreciate the response, this is what i was thinking
benbuilder is offline   Reply With Quote
