Old 04-14-2011, 02:36 PM   #21
MrTube
MrTube's Avatar
Default Re: Air Maze vs. No Air Maze
[QUOTE=Louis;192720]
Originally Posted by MrTube View Post
I think its easy to see how engine builders feel.
ALL production cars, motorcycles, dirt bikes, lawn mowers, generators have been shipping with air filters for over 50 years and its not because the manufactures want to spend extra money.
I also think most model A engine builders insist you run an air filter or it voids the warranty.
Unfortunatrly this discussion gets repeated almost as often as oil arguments .[/QUOTE ]
All prod. cars in the last 50 years have larger eng's. and draw in a heck of a lot more air then a 40 hp. 80 year old "A" does.
Dirt bikes and lawn mowers need an air filter for obv. reasons, and so does an "A" if it is driven on dirt/dusty roads most of the time.
On todays roads, if your "A" has eng. pans and the correct fan, most of the dirt/dust will be blow'n away from the carb. intake.
If your going to get an air maze, you might as well get an oil filter also, and why not a GPS ?
It's JMHO, but i don't think the air maze is worth even one fire .
The power of the engine as well as displacement is irrelevant and you are 100% right, the A engine does benefit greatly from an oil filter. GPS is optional.
MrTube is offline   Reply With Quote
Old 04-14-2011, 07:22 PM   #22
30Tudor
30Tudor's Avatar
I run the same set up as "Clydes". Has anybody built a shield to go between the filter and the carb to deflect any gas that may drip from the carb? If so, can you please send me a picture?
30Tudor is offline   Reply With Quote
Old 04-17-2011, 05:47 PM   #23
snowbird06
I put a KN E-2040 filter on my 30 A and it works very well......
snowbird06 is offline   Reply With Quote
Old 04-17-2011, 09:33 PM   #24
John Butts in CT
John Butts in CT's Avatar
Like snowbird06, I run a KN E-2040. I'm very happy with my engine's performance and with the muffled intake sound. The filter does fit above the engine pan.
Also, like at least one earlier poster, I highly recommend http://www.fordbarn.com/forum/showthread.php?t=30531
John Butts in CT is offline   Reply With Quote
Old 04-18-2011, 06:06 AM   #25
Jack '29 Sport Coupe
Jack '29 Sport Coupe's Avatar
Mine always ran fine with any of the filters, but the mileage is better on mine
if I use no filter at all. JMHO
Jack
Cincinnati, Ohio
Jack '29 Sport Coupe is offline   Reply With Quote
Old 04-18-2011, 06:20 AM   #26
Kevin in NJ
How many miles do you drive a year and how many dirt roads do you drive down?
If you are going to put many miles on your car or see a lot of dirt then you have greater concerns. Keep in mind that, unlike later engines, the Model A was designed to ingest dirt and still keep running. One of the advantages to the thick poured Babbitt was it could safely embed dirt and not hurt the crank. If you are running inserts then you might need to worry more.
Kevin in NJ is offline   Reply With Quote
Old 04-18-2011, 06:48 AM   #27
Special Coupe Frank
Special Coupe Frank's Avatar
Your car, your choice, your money....
Frankly, I think the super-size Air-Maze with the "duck-under" U-tube and pleated paper element or the K&N type filters are the way to go on a driver / tour car.
The original wire-mesh Air-maze looks nifty and "vintage" but can't begin to compare to modern filters or a decent oil-bath unit.
In the interest of full-disclosure, presently I'm not runing a filter on my '28... the air-maze fell-off and was crushed by the car behind me; but that engine is very tired, with 86,000 miles on it, and is definitely on its last legs before needing a rebuild. So I don't think the lack of a filter is going to greatly affect it's longevity.
When I get a re-built or better engine in my car, it WILL get a modern filter, and an oil-filter as well.
Special Coupe Frank is offline   Reply With Quote
Old 04-18-2011, 07:14 AM   #28
allen
allen's Avatar
Send a message via ICQ to allen
Kevin I think your dead on, also with the oils (non detergent) I don't think engines got the miles we expect today, a motor with 100k was way past its life, but with todays oil and filters 100k to me is very approachable
allen is offline   Reply With Quote
Old 04-18-2011, 10:40 AM   #29
RonC
RonC's Avatar
I prefer running without an air cleaner. The car made it 80 years without one and using an air cleaner muffles that "Model A" carb sound.
RonC is offline   Reply With Quote
Old 11-06-2011, 11:12 PM   #30
30Tudor
30Tudor's Avatar
I wanted to update this thread based on a question I asked earlier this year regarding building a shield for a "duck under" air filter assembly using a K&N 2040 filter.
I ended up building a shield using 4" heavy gauge galvanized heating duct as shown in the attached photos. It is cut out of one piece of tin and I soldered the tabs together on the one end . There is about a 3/4" gap between the top of the filter and the shield. The bottom is open.
I do get the occaisonal drip from my carb and at least now it is not soaking into the filter.
You can see in the pictures that I like filters!
I hope somebody can use this idea.
Old 11-06-2011, 11:59 PM   #31
MrTube
MrTube's Avatar
Originally Posted by 30tudor View Post
i wanted to update this thread based on a question i asked earlier this year regarding building a shield for a "duck under" air filter assembly using a k&n 2040 filter.
I ended up building a shield using 4" heavy gauge galvanized heating duct as shown in the attached photos. It is cut out of one piece of tin and i soldered the tabs together on the one end . There is about a 3/4" gap between the top of the filter and the shield. The bottom is open.
You can see in the pictures that i like filters!
nice!!!!
