Old 09-26-2024, 01:35 PM   #21
3W Hank
Default Re: Old FH race cranks ( before the 8BA )
A 3.7/16" bore ( MAX ) and a 3.785" stroke is over 280 cu in.
A 3.75" stroke ( same bore ) is 278 cu in )
Not much gain.
A classic Merc 4" and + 1/8" bore is 278 cu in.
3.75" stroke and 1/8" bore is 258 cu in.
My 41 truck-Merc/rised intake block is told to has ca 0.25" wall now ( sonic tested in Ca ) and bore is 3.3125" or 1/8" over std.
If I would 'dare' go 3.4375" I has wall that get thinner by 0.06".
3W Hank is offline   Reply With Quote
Old 09-26-2024, 09:50 PM   #22
Bored&Stroked
Bored&Stroked's Avatar
I would definitely have that block sonic tested again . . . as I find it hard to believe that it has that much wall thickness left. I have sonic tested a lot of these blocks and have never found one to have that amount of thickness after a .125 overbore. With that said, it is possible - but I have not seen it.
When you have it sonic tested have them do each cylinder in 12 places - top, bottom and middle of the cylinder - on four 90 degree locations at each level.
I would love to see the numbers!
Old 09-26-2024, 10:48 PM   #23
3W Hank
Yes, its still at the car shipper in LA.
No Swedes by cars theesedays as our money is nothing worth to USD plus everything has become expensive here to. So imports is zero to no..
Deal was in next box over, but they could not tell.
As soon its here I will get it tested, but I’m dont rely much on this tests as we are checking a machined sleeve.
Big bore is cool but can lead 8 sleeves, or just a hone at +125 and custom pistons.
Old 09-27-2024, 10:43 AM   #24
Ol' Ron
Ol' Ron's Avatar
Back in the early days 2 3\8 was the standard over bore. And yes a few 3 7/16 as well, Some times the compression was toooooo hi!!!\Gramps
Old 09-27-2024, 10:52 AM   #25
Bored&Stroked
If I'm building a high-performance flathead, I do not like to have more than about 2 sleeves in a block. When you get to 8 sleeves, it can really weaken the deck as most of the material that tied the deck to the rest of the block has been removed (to bore for sleeves).
Old 09-27-2024, 11:28 AM   #26
3W Hank
Yes I’m aware of that issue.
Old 09-27-2024, 11:41 AM   #27
tubman
tubman's Avatar
I hate to get down to splitting hairs, but is that per block or per side? Also, does it make a lot of difference if they are next to each other or not?
(Asking for a block I hope I'll never have to use.)
Old 09-27-2024, 11:42 AM   #28
tubman
tubman's Avatar
I hate to get down to splitting hairs, but is that per block or per side? Also, does it make a lot of difference if they are next to each other or not.
Old 10-01-2024, 01:10 PM   #29
3W Hank
I did checked out this crank today.
Std on both rod & mains.
Long nose and big mains/rods so it must be a 1939 early as rear seal was a slung.
Are that design bad, or caused leaks ?
If I got it right under 39 it was both slung and rope, so it cant be a 1940's crank.
Weight was 70.5 LBS or 32 kg.
Don't know weight of a 1945 crank or a Merc 4".
Old 10-01-2024, 02:22 PM   #30
Ronnieroadster
Ronnieroadster's Avatar
Hank Add at least 10 more pounds for the Merc.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 10-01-2024, 02:40 PM   #31
3W Hank
Yes I thought the Merc cranks is more beefy, but as I see it, can really the 1939 was lighter than ex 40 or 41 or exampla a 1945-47 crank.
This website said all cranks 36-41 had labyrinth seal.
As I heard it was a split 39 as early was sling, later was rope.
Question ; If anyone has a mid 40’s rope seal 59A crank, can you weight it ?
https://reds-vintage-parts.com/index...ch&search=1496
Old 10-06-2024, 04:49 PM   #32
3W Hank
Well….It was a move in the idea here.
Did not want get up at 49 but I came over a old stroked Merc 4” at + 1/8” from the guy I bought my Merc 41 block from in Californnia.
So if I stay on bore + 1/8” I get 285 cu in.
Price was right but it needs to be re-grind on the mains to .020”.
New bearings included and a set of NOS 21A rods.
Old 10-11-2024, 10:31 AM   #33
Bored&Stroked
If your current bores are tapered or out of round, the best thing is to go to the next oversize and bore/hone it again. I've done quite a few at 3 5/16 to .020.
You can get the pistons from Ross . . . just make sure they have the rings you'll be running before you order the pistons.
Old 10-11-2024, 03:45 PM   #34
3W Hank
Yes I will ask what rings will fit to the new bore, I just hone it to they goes clean.
