Old 09-11-2024, 09:20 AM   #21
Zax40
Zax40's Avatar
Default Re: 1940 Ford Coupe wheel alignment and steering wheel centering
IIRC tightening, or shortening the drag link should rotate the steering wheel to the left.
Zax40 is offline   Reply With Quote
Old 09-11-2024, 10:56 AM   #22
19Fordy
19Fordy's Avatar
Not sure if this will help but, here's what the drag link and tie rod set up looks like on my 40. To center my steering wheel, I adjusted the drag link that attaches to the splined steering arm part # 11A 3590-A that attaches to the steering box.
Old 09-11-2024, 11:56 AM   #23
glennpm
glennpm's Avatar
Originally Posted by std1940 View Post
Kube, Mike,
I have tried turning in both directions and can’t get the steering wheel in the sweet spot.
You are limited because of spindle orientation .
Turning the tie rod to where the steering would be centered makes it impossible to attach to spindle.
Thanks Tom.
Tom, I'd buy the one from Joe's and with it you will have fine adjustment. As Mart points out, without the sleeve, you have to make a full 360° rotation only, which isn't get you centered. If you have a show car stay with what you have but if you're driving it, and the wheel is driving you crazy, get one with the adjustable sleeve.
https://www.joesantiqueauto.com/drag-link-11y-3306
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 09-11-2024, 03:22 PM   #24
Zax40
Zax40's Avatar
I found my notes were still on my work bench from when I replaced my drag link a couple weeks ago. My old drag link when removed (steering was centered) was 32 9/16 when measuring from the outside of the lube fitting to outside of lube fitting on far end. This won't be exact for every 40 Ford but it might help get you in the ball park.
Old 09-11-2024, 03:26 PM   #25
Kube
Super Moderator
Kube's Avatar
Kube, Mike,
Thanks Tom.
Post #20 is spot on with that advice. It sometimes takes me three times to get it right.
Old 09-11-2024, 06:14 PM   #26
std1940
std1940's Avatar
I would like to thank everyone for their ideas,advice guidance and suggestions!
Tom.
std1940 is offline   Reply With Quote
Old 09-14-2024, 07:41 AM   #27
Gene1949
Gene1949's Avatar
find another alignment shop.
Gene1949 is offline   Reply With Quote
