Old 06-27-2024, 06:29 AM   #21
Jake dalka
Default Re: Vapor lock?
Flathead Fever’s suggestion is easy and eliminates one of the two possibilities….
My feeling is fuel problem…..you said it starts after you pour fuel in carb…of course you
have to consider how much time elapses before you pour fuel…..too long …temp might drop enough To revive electrical components
Jake dalka is offline   Reply With Quote
Old 06-27-2024, 08:03 AM   #22
FrankWest
FrankWest's Avatar
Originally Posted by koates View Post
Frank has not mentioned that his 33 Ford is a 4 cylinder so rebuilding the coil is not an option. Regards, Kevin.
Kevin,
They can't rebuild my coil? Good to know.
FrankWest is offline   Reply With Quote
Old 06-27-2024, 11:48 AM   #23
JimG
JimG's Avatar
Here is a website that lists gas stations that sell non-ethanol gas in the US and Canada.
https://www.pure-gas.org/
JimG is offline   Reply With Quote
Old 07-05-2024, 11:14 AM   #24
FrankWest
FrankWest's Avatar
I replaced the ignition coil, the condenser, the engine still runs for 30 minuets and then stops, make and excellent timer. Every 30 minuets. I think if the mechanical pump were bad it wouldn't run for 30 minuets right. It seemed like I could accelerate better without as much engine coughing.
Old 07-05-2024, 12:59 PM   #25
TwoDuckDad
TwoDuckDad's Avatar
they also have an app that allows you to find ethanol free fuel and will give directions to the station. Very handy when on the road and needing fuel. I use ethanol free fuel in my 41 Pickup, my boat, and all my yard tools. Can't get the wife to go to the trouble to find a station with that fuel for her Durango R/T but at least she knows how to fuel her own vehicle . We used to live in Oregon (but not Portland) and couldn't pump your own fuel.
TwoDuckDad is offline   Reply With Quote
Old 07-05-2024, 01:11 PM   #26
Flathead Fever
Flathead Fever's Avatar
I was a phone company mechanic for 30-years. We had almost 400 vehicles in our yard, and we kept them for a long-long-time. During that time, I only saw one vehicle experience vapor lock. It was a Chevy Suburban that went up into mountains. When it was around 5000' elevation, on a very hot day, it would just quit. The driver would let it sit for a while and then it fired right up. We'd go up and get it, drive it down the hill to the shop which was at around 1000' elevation where our yard was at, and we never had a problem with it. We worked 4pm to 11:30pm, so by the time we took it back up to its parking spot in the mountains it had cooled down, we could not duplicate the problem. So, we started throwing parts at it, ignition module, coil and everything else we could think of. Still every once in a while, the Suburban would quit but just up at higher elevation in the mountains. One time I was taking it back up the mountain and it was still hot out and it quit, just like it ran out of gas, I pulled over and poured some water on the fuel pump and it started right up. I took it back to the shop and put a fuel pressure gauge on it and it was down just one pound of pressure from the 5 to 6 lbs. specifications. Replaced the pump and that fixed it. That was a form of vapor lock from the high altitude, but the problem was the fuel pump. The thing is it had run all those years without any problems, so you don't want to go redesigning everything you just need to find the problem, sometimes it just kicks your butt. I've had stuff in fuel tanks that after driven for a long time it would get sucked up against the outlet hose and the engine would die. As soon as the vacuum was gone it would unplug itself and drive for a while longer.
On my dad's flathead powered '32 roadster I've taken a 5-gallon can of gas and a 1 1/2 lb. electric fuel pump. stuck it in the cab and bypassed the entire fuel system. That way I knew for sure if it's a fuel problem (be careful). I have the tank out of it right now, it was full of junk. And then I had a stroke, so it hasn't gone back together yet. You could tee in a pressure gauge on the output side of the pump and see what the pressure is when you first start it and then what it is when it quits.
Flathead Fever is offline   Reply With Quote
Old 07-05-2024, 01:18 PM   #27
Fritz
Fritz's Avatar
There could be some other issue going on, but with the low quality of new points, condensers, coils, etc one of those could still be your problem. This is what drove me to a Pertronix ignition, and I have not looked back. They make a unit for Ford 4 cylinder positive ground.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 07-05-2024, 05:23 PM   #28
petehoovie
petehoovie's Avatar
Old 07-05-2024, 06:05 PM   #29
FrankWest
FrankWest's Avatar
I will next rebuild my fuel pump. Perhaps it is marginally working and eventual cuts out?
Old 07-06-2024, 06:45 PM   #30
FrankWest
FrankWest's Avatar
I went out this morning and figured everything was cooled down. I could not start the car even after pouring a little gas into the carb. Usually always works.
The battery was very low. I am trickle charging it now. This happen one time before when the car stopped running. I noticed then that the batter was low.
Could a low battery kill an engine? The last time that happened I charged the battery and the car started up and ran perfectly.
Old 07-06-2024, 07:12 PM   #31
oldbugger
oldbugger's Avatar
A low battery will kill the engine if your not charging when running
oldbugger is offline   Reply With Quote
Old 07-07-2024, 06:46 AM   #32
FrankWest
FrankWest's Avatar
Thanks,
I have to check my generator to see if it is working. maybe this was always the cause of the problem?
Old 07-07-2024, 08:15 AM   #33
51504bat
51504bat's Avatar
See post #16 on this thread
https://www.fordbarn.com/forum/showt...76#post2322776
Old 07-08-2024, 06:35 AM   #34
FrankWest
FrankWest's Avatar
Thank for taking time to give details. I learned a lot from you and will continue to troubleshoot.
Old 07-08-2024, 06:51 AM   #35
FrankWest
FrankWest's Avatar
Went out first thing this morning poured a little gas into the carb. The car won't start at all. Whatever was going finally went all the way. Now the fun begins?
Old 07-08-2024, 07:09 AM   #36
vincent
Compression will not go away on all pots within days so your engine has probably only fuel or ignition problems. If battery is fully charged and voltage reaches the coil,First check for a healthy spark, next is spark timing. Change or clean those wet plugs before attempting another start. If carbs float chamber is full, engine should start and run for a couple seconds even without a working fuel pump.
vincent is offline   Reply With Quote
Old 07-08-2024, 08:35 AM   #37
FrankWest
FrankWest's Avatar
Thanks Vincent for your clear advice. I will do as you recommend.
Old 07-08-2024, 06:41 PM   #38
FrankWest
FrankWest's Avatar
removed spark plugs, carbon buildup on all 4 plugs. I cleaned them and put them back in the engine. Tomorrow I will check for a spark. I guess I need my wife to step on the starter while I and holding a plug, welders gloves to see if I get a spark.
Old 07-09-2024, 01:32 PM   #39
FrankWest
FrankWest's Avatar
my car ammeter was jiggling when trying to start, but still not start.
I guess coil is ok but not have to check from distributer contact to spark plug. One strange thing was horn works but headlights do not? What the hell is going on?
