Old 06-24-2024, 07:42 AM   #21
kurt v
Default Re: New Brake Master Cylinder Leak
Almost looks like the brass fitting might be hitting the master cyl on the left side keeping it from pulling up,
kurt v is offline   Reply With Quote
Old 06-24-2024, 10:11 AM   #22
Bored&Stroked
Bored&Stroked's Avatar
Probably too thin of copper washers . . . . as somebody wants to save money on the copper used!
Old 07-17-2024, 11:29 PM   #23
mgm60
mgm60's Avatar
Update:
Finally stopped the leak. Doubling the copper washers did not work. Bought these speciality washers from Earls, recommended by someone over on the HAMB and also used this sealant recommended by 19forty. Thanks for all the suggestions and hopefully this helps somebody with the same problem in the future.
mgm60 is offline   Reply With Quote
Old 07-18-2024, 02:13 AM   #24
vincent
Are you sure your brakes will work if you seal them with some liquid glue and a rubber o-ring that is already squeezing out at the edges of the hexagon? IMHO these seals are never meant to take the pressure of a hydraulic brake. I would not ride with you....
vincent is offline   Reply With Quote
Old 07-18-2024, 08:19 AM   #25
tubman
tubman's Avatar
I was thinking the same thing. This appears to be a "band-aid" at best.
tubman is online now   Reply With Quote
Old 07-18-2024, 09:34 AM   #26
glennpm
glennpm's Avatar
You mention two new master cylinders. Are the exit holes threaded deep enough? The new washer you used is thicker and would overcome this. You may want to trial fit with no washers and check that the banjo bolt can be tightened up enough so the brass block can't be rotated?
Glenn
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 07-18-2024, 02:58 PM   #27
69a
Originally Posted by mgm60 View Post
Update:
I would be very dubious about using those rubber washers! Are they even compatible with brake fluid?
69a is offline   Reply With Quote
Old 07-18-2024, 03:38 PM   #28
Blindhuckster
Blindhuckster's Avatar
I had the same issue with a new master cylinder a couple years ago that I purchased from Dennis Carpenter. Leaked in the exact same spot. I tried multiple times with different washers without resolve. It seemed to me that the master cylinder outlet port was not drilled squarely and was drilled at an angle from looking at the washer. They were only seating on one side of the washers. Ordered a new replacement master cylinder, washers and block fitting from the early ford store and that solved the problem.
Nate
Blindhuckster is offline   Reply With Quote
Old 07-18-2024, 06:21 PM   #29
69a
Nate
Finally a solution that makes sense! Good spotting, Nate.
Easy to check with feeler gauges. Send it back to the seller for a refund or replacement. It is "NOT FIT FOR PURPOSE".
