Old 06-16-2024, 11:21 AM   #21
700rpm
700rpm's Avatar
Default Re: Zenith 1 Carburetor leak trouble
That’s a very generous offer, Gary. Thank you. I’m gonna fuss with it a little more, and I might just give it up and buy one the rebuilts offered on the MAFCA site. I’ll let you know.
Ray Horton, Portland, OR
Old 06-16-2024, 08:12 PM   #22
700rpm
700rpm's Avatar
You were right, Fred. Best suggestion of all. I did that today. New carb arrives next week.
Old 06-16-2024, 08:14 PM   #23
700rpm
700rpm's Avatar
Thanks again, Gary. I’ll keep the leaker, but I ordered a new rebuild today.
Old 06-25-2024, 08:18 AM   #24
Canton_Model_A's
Canton_Model_A's's Avatar
700rpm, you might be able to send off your leaking carb over to Dave Renner he might be able to go thru it and let you know what is up. I have a rebuilt Zenith from him and a Marvel as a just in case carb for touring. Can't hurt to give him a try.
1929 Model A Tudor - "Darla"
'29 Model A: Old enough to start with a crank, young enough to steal the show!
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
Old 06-25-2024, 12:58 PM   #25
rich40701
rich40701's Avatar
I thought my drain plug was leaking and I changed the gasket multiple times with multiple materials and kept messing with it until I stripped the threads out. It turned out all along it was leaking out the bottom weep hole due to bad float adjustment or jets not properly seating not sure exactly which. I purchased the float adjustment tool from Renner's and found a drain plug that had a few more threads and no longer have a leak issue.
rich40701 is offline   Reply With Quote
Old 06-25-2024, 01:07 PM   #26
Brentwood Bob
Eventually the hard ones get fixed.
Brentwood Bob is offline   Reply With Quote
Old 06-26-2024, 12:06 PM   #27
700rpm
700rpm's Avatar
Originally Posted by 700rpm View Post
Thank you Jim and Gary. I’ve been reluctant to put any sealant on the plug because of its proximity to the Main jet. But I’ll approach it with caution and see what happens. I’ll report back the results.
Reporting back: I tried all sorts of remedies to stop the leak: socalled gas proof sealants, different plugs and washers, checked and confirmed floe rates and jet sizes, Nothing worked. I drained it, put it on a shelf, and ordered a new rebuilt one from TheModelAGuy on the MAFCA Classified site. Someday I may revisit that carb and check the body for seepage.
Old 06-26-2024, 01:32 PM   #28
Brentwood Bob
Sometimes you just punt.
Old 06-27-2024, 10:02 AM   #29
katy
katy's Avatar
????? What does that mean?
Old 06-27-2024, 11:24 AM   #30
Brentwood Bob
As in throw up your hands in utter frustration.
Old 06-27-2024, 11:25 AM   #31
ursus
In US and Canadian football a punt kick is used by the offense to advance the ball downfield when run or pass options have been exhausted. Canadian punt rules are more complex (fun) and retain vestiges of rugby football.
ursus is offline   Reply With Quote
Old 06-27-2024, 03:06 PM   #32
sunnyorm
sunnyorm's Avatar
FWIW;
https://www.vintagefordforum.net/for...-1929-zenith-1
sunnyorm is offline   Reply With Quote
Old 06-27-2024, 03:09 PM   #33
sunnyorm
sunnyorm's Avatar
Please delete; link didn't work?
