Old 06-10-2024, 04:02 PM   #21
Ggmac
Default Re: Lowering shackles source
I just took measurements rear 26 1/2 with 215-75-15 the top of my tire is aprx 1-2”above the rear fender lip . That could be off because I’m not 100% level , side to side .
Ggmac is offline   Reply With Quote
Old 06-10-2024, 04:47 PM   #22
Fairlane514
I agree TJ, Tire fitment first then lowering if possible.
Ggmac.....I will try your measurement. I just measured up from the ground to the bottom of fender lip......25 3/4 rear, 27 1/2 front.
Anybody like raised white letter or outlined white letter tires.......I like to push peoples buttons sometimes.
Fairlane514 is offline   Reply With Quote
Old 06-10-2024, 04:55 PM   #23
Ggmac
You won’t get the 235s on let alone off if you have the original rear end and using mid 60s 15-5 1/2” rims .
Old 06-10-2024, 06:03 PM   #24
Fairlane514
Ok, so 215's or MAYBE 225
Old 06-10-2024, 06:55 PM   #25
Fairlane514
Placed a straight edge on top of my rear tire inside the wheel well (fender).......Looks like little less than a 1/2 inch "tucked up" into the fender.
https://www.fordbarn.com/forum/attac...1&d=1718063686
Old 06-10-2024, 07:11 PM   #26
Ggmac
That spring does look alot flatter than mine . What angle are your shackles at ? I see you have tube shocks , nice . I just went through a week of r&r rear shocks , adding correct oil , adjusting, installing new links etc . Tube shocks are so much easier .
Old 06-10-2024, 07:19 PM   #27
petehoovie
petehoovie's Avatar
Old 06-10-2024, 07:52 PM   #28
Fairlane514
The shackles appear to be in the 45 degree neighborhood. They 2 1/2 inches center to center.
I just got this car, so the shocks were done by previous owner.
Old 06-10-2024, 10:31 PM   #29
TJ
TJ's Avatar
If the 215X75's are already tucked up inside the fender by 1/2" you will not be able to put a bigger tire on the car.
