Old 12-14-2025, 11:36 PM   #21
FlatTopFreddie
Default Re: Timing advance plate - Crab Distributor
There is an article on VanPelts site that will help you find that answer …
http://www.vanpeltsales.com/FH_web/f...str-timing.htm
FlatTopFreddie is offline   Reply With Quote
Old 12-15-2025, 03:36 AM   #22
Mart
Mart's Avatar
Crank turns clockwise. Cam is geared so turns counter clockwise. Distributor shaft turns counter clockwise. So to advance timing turn plate clockwise. To retard turn counter clockwise. Translate that rotation to up and down screw movement depending on which side it is mounted.
All as viewed from the front of the motor.
Working things out from first principles is better than asking.
Mart.
Old 12-15-2025, 06:46 AM   #23
glennpm
glennpm's Avatar
Mart.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
