05-11-2024, 08:45 AM | #21 |
Re: Oil leak
I'd keep the pipe.
05-11-2024, 09:02 AM | #22 |
Re: Oil leak
I'm with Kube - it surely won't hurt the situation. Another potential is for there to be an issue on the rear cover that bolts to the block behind the flywheel -- it has a thin gasket and potentially there could be a leak in this area. Other than the oil galley plug (underneath it) and this cover, the only other place oil could be coming from is the rear main.
05-11-2024, 12:34 PM | #23 |
Re: Oil leak
Bored&Stroked, I watched the leak with the engine running, and applied a shop vacuum suction close to the road draft tube, it stopped the oil flow. It seems if the oil was from a pressure source, such as the plug or plate over the pump to cam gear the vacuum would have no effect, but it completely stops the flow. I hope to drop the pan and find something obvious. We'll see.
05-11-2024, 02:06 PM | #24 |
Re: Oil leak
Road draft tube?
Oh, by the way, be certain the breather at the front of the pan is "open". The correct pan gasket goes around this area.
05-11-2024, 03:41 PM | #25 | |
Re: Oil leak
From page #61 through #66 of the Techno Source ... below "Rear Crankshaft Sealing From 1932 to sometime in 1941, Ford used a non-contacting crankshaft thin flange that whipped oil into block and rear main bearing pot metal channels to prevent oil escaping. However,since there was no crankshaft to material seal, i.e., rope seals; leakage could occur due to crankcase pressure or just pour out if the engine was tilted to the back such as parking uphill" Glenn
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat's Notes Techno-Source for the 1932 thru 1953 Flathead Ford Last edited by glennpm; 05-11-2024 at 03:48 PM. |
05-11-2024, 04:03 PM | #26 | |
Re: Oil leak
05-15-2024, 02:46 PM | #27 |
Re: Oil leak
An update, I made a pan "diaper" to catch the oil and drove it under varying conditions for 20 minutes. In that time it pumped out over a quart of oil. Next I started to remove the oil pan, but can't quite get it out, hangs up on front crossmember, and can't get the front any higher. I did notice that the pan gasket behind the oil pump could be allowing oil out. I don't recall the oil pump to block having a seperate gasket, should it? Could pressure oil leak out there and be the culprit? Pulling engine next, and that is a PITA
05-15-2024, 02:51 PM | #28 |
Re: Oil leak
Pulling the engine won't be as much trouble as you think. I had the engine, transmission and rear end out of my '37 tudor in about 6 hours. I was working by myself until I needed a hand for a few minutes with the engine hoist.
05-15-2024, 02:56 PM | #29 |
Re: Oil leak
You may be able to pull the pan by rotating the motor. Either #1 or#5 rod bearing caps may be causing the hangup.
Firing order is 1-5-4-8-6-3-7-2
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat's Notes Techno-Source for the 1932 thru 1953 Flathead Ford Last edited by glennpm; 05-15-2024 at 03:37 PM. |
05-15-2024, 03:06 PM | #30 | |
Re: Oil leak
05-16-2024, 05:14 PM | #31 |
Re: Oil leak
Just an update, I pulled the engine, pulled off the pan, and have found no smoking gun. I still have the flywheel to pull off to check the cam to oil pump cover. The pan to block and around the cork seal at rear bearing all looked really good. I will keep trying to solve this leak situation.
05-16-2024, 07:17 PM | #32 |
Re: Oil leak
Is your dipstick correct with the correct measured amount of oil ? Just a possibility?
Good luck |
05-16-2024, 07:33 PM | #33 |
Re: Oil leak
What oil pump do you have in there ? With the engines with a slinger at the rear I like a stock pump and a rather tight clearance on the rear main crankshaft journal.
05-17-2024, 08:55 AM | #34 |
Re: Oil leak
Oil dip stick is correct, and I only use 4 quarts of oil at each change. I installed the "standard flathead pump by Melling" sold by Speedway. I can probably check the rear clearance with plastigauge.
05-18-2024, 09:12 AM | #35 |
Re: Oil leak
I have not found the issue yet but have eliminated some things. The oil leak is not from the cam to oil pump cover or the plug in the end of the oil passage in the block. Using compressed air I can get oil to bubble around the pump at the block, and hear it at the timing gear going past the flat spot on the pressure valve. At this point it seems to be either too much oil pressure, too much clearance on rear main bearing, or too much blow by from rings not having completely seated. I will keep digging.
05-18-2024, 10:03 AM | #36 | |
Re: Oil leak
05-18-2024, 10:41 AM | #37 |
Re: Oil leak
You could try a stock lower-pressure pump - as it currently appears to have the later 49-53 pump - which will put out more volume and pressure than stock.
While I hate to mention an alternative direction, but here goes. You already have the engine out of the car, so why not think about pulling the crankshaft, having the slinger ground off and switching over to the later rope-type seal plates? You'll only have a few more hours of work to do this . . . and it beats putting it all back together (even with a new pump) - only to see the same problem once again. Or just put a later crankshaft in it . . . |
