Old 04-30-2024, 08:25 AM   #21
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Merc 1939 axle in a 32 frame need help with torque tube lenght
What's the advantage of a '39 rearend in the '32? Seems like a lot of work for a result that makes you go down the road all the same?
Seth Swoboda is online now   Reply With Quote
Old 04-30-2024, 08:27 AM   #22
Cheaterpete
Much stronger rear axle, hydraulic brakes.
Cheaterpete is offline   Reply With Quote
Old 04-30-2024, 08:57 AM   #23
rockfla
rockfla's Avatar
Seth
Not trying to be an antagonist or smart donkey here BUT I am STILL trying to figure out......"IF" he already "have a complete 39 Mercury axle", why did he need the torque tube measurement, couldn't he just measure the rear end he has???? BUT what do I know???
Old 04-30-2024, 08:58 AM   #24
Cheaterpete
the 39 axle center section is not the same size, the swap is not bolt on and the torque tube on the 39 is way longer ths need to be reduced.
Old 04-30-2024, 01:52 PM   #25
Mart
Mart's Avatar
Which year Mercs had the oddball one piece driveshaft/pinion?
Old 04-30-2024, 02:05 PM   #26
rockfla
rockfla's Avatar
Mart
I "think"??? Through 41. I have the torque tube and shaft and ring gear I picked up out of a 40 Mercury that is one piece.....SO at least through 40.
Old 04-13-2025, 06:29 PM   #27
dialindicator
I have been searching to find the stock or common axle ratio for a 1939 Mercury with little success. The one I have is 410 but would rather 378 if it was available and if I can find one. I could change to the normal short pinion and modify the driveshaft to use a coupling but that is a daunting task. Any thought or suggestions would be appreciated. Thanks, Bruce
dialindicator is offline   Reply With Quote
Old 04-14-2025, 09:34 AM   #28
hotcoupe
hotcoupe's Avatar
Pete, you can avoid the hassle and put a late '32 rear axle in your car. I have one available for sale, if you're interested. P.M. for details.
Tom
hotcoupe is offline   Reply With Quote
Old 04-14-2025, 09:35 AM   #29
Shoebox
Shoebox's Avatar
I have a '39 Merc Town Car and its ratio is 3.54. I have a Columbia rear end built with a 3.78 gear set that came from a 1940 Mercury. Hope this helps.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
