#21 |
For those of you who, like me, don't know what a Lenco transmission is, it is a stack of planetary transmissions, each with its own gear shift knob. See https://lencoracing.com/.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 03-12-2024 at 05:51 AM. |
#22 | |
#23 | |
I've read that some mix both 85W-140 gear oil and STP, half and half in their tranny.
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
#24 |
For a while, 600W oil was (um) substituted with something else. There was complaints on the quart cans of oil everyone was buying from "proven" Model A vendors.
One of the nice features of working in a power plant is that "period" machinery frequently require "period" lubricants. One of these was ACTUAL 600W oil which was assured to meet the SAE standard. Quality Assurance was and is a major motivating force when up to $1M per day is lost on a unit outage. The standard number and grade was actually on a sheet glued to the top head of the 55 gallon drum. This is the standard which has been revised bi-annually for many years. Automotive Gear Lubricant Viscosity Classification J306_201902 $92 and you too could own the actual standard. Of course I grabbed a gallon or two while I was there. I've mentioned the STP. In the punkin I use 600W oil. I feared that "slinging" of the oil on the gear would be impeded if I used STP in this application - and this might cause undue "working" of the oil - and consequent heating of the oil. Which might "undo" the stick/pressure capability of the oil. Dunno - it's not exactly rocket science. But it is nice to have "actual" 600W oil as an option. Joe K
Shudda kept the horse. Last edited by Joe K; 03-12-2024 at 08:44 PM. |
#25 |
#26 |
#27 |
All the above is good advise. Using the stock transmission the biggest novice driver
problem I see is trying to drive the car like a modern car and and revving the motor to high going into 2nd gear. As stated above it needs a "short shift" (shifting at a lower motor speed.) You should be in 2nd gear before you cross an intersection. The double clutch is not necessarily needed mechanically but it gives the right amount of time to make the shift letting the gears mesh. |
#28 |
My car has a 39 trans (2 & 3 syncro) with the Cling's adapter. The adapter kit is around $800 and you'll need a trans. The Mitchell trans is about $2,400 and the OD is about 3,400. You could go with a T5 trans and end up will a full syncro 5 speed with overdrive $900 plus the trans. https://www.lainefamily.com/ModelAFiles/ModelAT5.htm
#29 |
Or you could go with a A4LD and not worry about shifting at all...
#30 | |
#31 |
I’m on the waiting list for a Snyder synchronized. I just bought my dad’s old 31 coupe. My mom and dad toured a lot in it. 106k miles/49 states from 2002-2022. After 95 yrs, plus, those additional touring miles and it needs a new transmission. I plan to drive this car a lot and with Atlanta traffic, having to shift so slowly and the huge gap between 2nd and third is a big safety concern and it’ll get used a lot more. I don’t know how they never got hit before with how much they held up traffic and I’m trying to mitigate risk. It already had overdrive and a high compression touring motor so driving hwy speed isn’t an issue. He had the brakes really dialed in too. It stops surprisingly good with only a cast iron drum upgrade over stock.
