#21 | |
#22 | |
Mike 425-478-1271 txt ok |
#23 |
Hey Mike, add a picture of your blue Coe for an avatar. Then create some albums in your User CP "photos and albums" and upload pictures of some of your big iron. I am sure guys here would love to see your 39 too.
#24 |
Thanks to all that replied!
I am looking for the front bearing retainer for a Cadillac Laselle transmission. Also hub that holds throw out bearing and clutch arm. Any leads appreciated. |
#25 |
My former 39 Ford Coupe had a 331 Cadillac backed by a 1937 LaSalle floor shift 3 speed transmission. Here is a picture of the motor mounts in place. Sorry - do not recall what manufacture they were.
#26 |
#27 | |
#28 |
#29 |
Everything "PeterC" does turns out to be a real beauty! Coop . |
#30 |
Super Moderator
A friend of mine did this '39 coupe and I will say, he did a good job. No shortcuts...
Classified Ads - 1979 and Older Cars For Sale - 1939 Ford Deluxe Coupe - Classic Cars & Trucks For Sale - Northwest Classic Auto Mall (nwcam.com)
#31 |
I do not enter very often. I bought a pair for a Cad install in my 26 Ford coupe. If I remember correctly I looked under Hot Rod or Ra$ Rod Cadillac engine mounts. Very seldom
do you find a Hurst set. Good luck |
#32 |
A few pictures of my former Cadillac/LaSalle 1939 Coupe - Powered by a 1951 Cadillac 331 ci bored to 365cu backed by a 1937 LaSalle 3 speed top loader floor shift. 1951 Cadillac Engine 365 cu in (bored from 331ci) 4" JE forged pistons Stock Crank and rods Eldorado dual quad intake - WCFB Carter carburetors Eldorado big port heads Eldorado exhaust manifolds Eldorado "Batwing" Chrome intake air cleaner Chrome Cadillac valve covers Nielson Vintage Racing Cam - 432 lift/282 duration 2" dual exhausts 275hp/344 ft lbs at the rear wheels - dyno reports included 11" Weber Clutch Front Suspension - 4" dropped front axle (NOS Cragar) Rear Suspension -- 2 " drop - Chassis Engineering rear suspension Chassis Chassis Engineering parallel rear springs 9" Ford 3:50 rear plus traction bars Custom open driveshaft with front yoke slip joint 5.5 bolt pattern wheels all around .5.5" front - 1950 Mercury 6" Rear - 1950 Lincoln 41 Lincoln Front Brakes |
#33 | |
#34 | |
http://www.nwcam.com/ClassifiedAds.h...d=13811&step=4 |
#35 | |
#36 |
Just sent my early 51 and 52 Cadillac distributors to Charles Schwindler in New York. He is going to modify/update them with later fly weights and vacuum advance to use manifold vacuum. I will try to post some photos when I get them back.
#37 |
Did you find your bell housing to do the install ? Years ago I bought one believing it would fit my '52 engine , but it may be for the later engine that you have . I'm still looking for an early style adapter . Maybe we could trade ?
#38 | |
TomC750 1949 8NV8 Ford tractor 1930 1 Ton White 1941 Mercury Sedan Coupe |
#39 |
#40 |
