Old 01-16-2024, 01:41 PM   #21
glennpm
glennpm's Avatar
Default Re: Ball bearing for 1932 steering lock
Thanks David. Joe is my first stop and I checked in an older catalog and the parts weren't listed. I've just ordered them.
Thanks!
glennpm is online now   Reply With Quote
Old 01-16-2024, 01:44 PM   #22
glennpm
glennpm's Avatar
Prices are great too!
Old 01-16-2024, 02:16 PM   #23
DavidG
DavidG's Avatar
You're welcome!
You're also fortunate that the black plastic back cover isn't cracked as they often are from over-tightening the two screws.
Old 01-16-2024, 06:45 PM   #24
32phil
If you look at the two column drop photos posted by glennpm in post#19 you will see the top photo shows a drop completely cut out. In the bottom photo the column drop is not cut out and shows just two round holes.
When the drop is cutout, it makes it possible to remove the slide without removing the locking pin. Just push it through passing thru the toggle lever.
I modify every drop I refurbish it makes things so much easier.
Only a small slot is needed just enough to pass the pin through.
I hope this helps.
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 01-16-2024, 06:59 PM   #25
glennpm
glennpm's Avatar
That’s very good to know, thanks
Glenn
