Old 01-01-2024, 12:30 PM   #21
Bud
Bud's Avatar
Default Re: Ford Rear Brake Drum repair
I have a complete set of 1935 brake drum assemblies, front & rear for sale on another site. PM me for more details.
Bud is offline   Reply With Quote
Old 01-16-2024, 11:44 AM   #22
Macdozer
The Dorman 610-234 studs won't work, to small
The stud hole in the drum is 0.624 diameter.
I'm trying to find the correct original wheel studs but not having much luck.
I believe I'm looking for part number 48-1118 rear studs.
Macdozer is offline   Reply With Quote
Old 01-16-2024, 02:42 PM   #23
Tim Ayers
To be clear, the original ones will need to be swedged. I would make sure you or your shop can do that. I believe you need a 20 ton press and the correct swedging dies
Old 01-16-2024, 08:02 PM   #24
Macdozer
Correct about the swedging
But can’t find the correct studs that will need to be swedged
Old 01-16-2024, 08:08 PM   #25
v8nut
v8nut's Avatar
You could try All Ford Parts in Campbell Ca. Jim in San Jose
v8nut is offline   Reply With Quote
Old 03-06-2024, 03:37 PM   #26
Macdozer
Haven't had any lock locating the correct studs.
