08-26-2023, 10:39 AM | #21 |
Re: What’s up with this mercury crank gear (backwards?)
So should I install the timing gear cover before the valve train?
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
08-26-2023, 12:04 PM | #22 |
I'd install it without a gasket first and check cam end play before installing valves. Just snug up the bolts and see what you have...if it gets tight install a gasket and check again. Mine was perfect without a gasket so I used anaerobic sealer on final installation. I also left the cover on temporarily to keep the cam in place while adjusting valves. Then removed and reinstalled with sealer.
Terry
08-26-2023, 01:31 PM | #23 |
As Terry above wrote I also check the cam end play without a front cover gasket. Example just today on an 8BA I'm building checking the cam end play without a gasket between the front cover and block the end play was.010. The cam was a nice used Melling Tool Company performance grind which they offered in the 60's the front cover had the typical visual wear from this cam and also its previous life with the stock Ford cam.
Its rare I ever use a front cover gasket. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
08-26-2023, 01:37 PM | #24 | |
Hi Dale Dan may not have a V-8 set of gears ready to go he's more involved making the four cylinder items. Once you have the set of gears you will find the holes drilled in the cam gear will not be helpful for cam timing. Also since the cam gear is steel you will find its very heavy. I have many hours into the cam gear removing metal I can say its still heavier than the aluminum gear. Ronnieroadser
08-26-2023, 04:24 PM | #25 |
Dan's spur gears that I have used were aluminum and I did lighten them also. Circle track engines need to spool up faster than LSR engines.
08-27-2023, 12:53 PM | #26 |
08-27-2023, 12:56 PM | #27 | |
Were BOTH your gears steel from Dan? Did you also install something (similar to a cam thrust bearing/button on a SBC) to force the thrust toward the block? |
08-27-2023, 02:29 PM | #28 |
08-27-2023, 02:41 PM | #29 |
Dale:
If you use a press-on gear type core, you don't need any fancy holes or systems. If you adjust the gear location on assembly, I guarantee it is faster than adjusting a bolt hole system. You do not have any cam walk when installed properly. No fancy thrust buttons/bearings needed. |
08-28-2023, 04:44 AM | #30 |
Thanks guys! I have an eMail message into Dan . . . to see what he may or may not offer these days. Take care!
08-28-2023, 10:35 AM | #31 | |
Interesting. Are you referring to the early stock style cams with the press on gears? I know Ford made an aluminum version of this gear. I always just assumed that arrangement would eventually slip, but go goes show what little I know. Tim |
08-28-2023, 01:15 PM | #32 |
Tim: Yes, that is what he is referring too. There is an aluminum version - works great if your cam core is the type that can use it.
You can always add a 'grub screw', roll-pin or put a small TIG tach on it if you're running a lot of spring pressure and are worried about it. |
08-28-2023, 08:33 PM | #33 | |
I have found using straight cut gears and a wet oil sump the cam will move forward. The oil pump drive will push the cam forward so that needs to be addressed. My experience is with the latter 8BA cam. This movement will create a retarding ignition issues the amount depends on how much movement is allowed. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH Last edited by Ronnieroadster; 08-28-2023 at 08:39 PM. |
08-28-2023, 08:44 PM | #34 | |
I remove the oil drive gear from the cam also. |
