Old 08-10-2023, 09:48 PM   #21
Tom in TN
Tom in TN's Avatar
Default Re: Seeking troubleshooting experience
Well, for those watching- I believe I may have found the source of my multiple mis-firing.
I got the radiator out, removed the distributor and started looking...One set of points looked pretty typical and was something you could touch-up with emery cloth. But the OTHER set of points had some very lousy tips. Pits, bulges and crust were all you could see. I call them burnt up.
So, if one set is burnt up, wouldn't that lead to a mis-firing engine?
FYI, me and points are not gonna do this dance again. I talked to a tech at Pertronix and he gave me the ignitor part number for my Mallory Dist and I will be running a Pertronix unit.
Tom in TN is offline   Reply With Quote
Old 08-11-2023, 10:03 AM   #22
deuce_roadster
deuce_roadster's Avatar
You may have 2 bad coils. OF course, that is what the Pertronix person would tell you to do.
I have points in all my flatheads and have zero problems with any of them.
Old 08-12-2023, 08:08 AM   #23
Planojc
Planojc's Avatar
You can save yourself a lot of headaches if you take your distributor to Third Gen. and let them do their thing to it.
Planojc is offline   Reply With Quote
Old 08-22-2023, 05:39 PM   #24
Flatmotors
You may have vacuum leaks from the intake, or the condenser may be bad. Good luck!
Flatmotors is offline   Reply With Quote
Old 08-24-2023, 04:28 PM   #25
Tom in TN
Tom in TN's Avatar
Ok, y’all. This post is meant for those who have been patiently waiting to find out how things worked out with my 34’s engine…so here we go.
What I changed:
New Pertronix Flame Thrower coil
New Pertronix Ignitor kit #ML-181; fits my Mallory Dist.
New Accel plug wires (yes, still yellow)
New Autolite plugs
New fuel pressure gauge –showing 3lbs on the nose
Radiator was repaired and pressure tested.
2 new lower radiator hoses lubed with NAPA Sil-Glyde
The verdict?
It runs like a dream without ANY sign of missing AT ALL.
Idles low and steady but still takes a foot in the carb without hesitation.
I call this a success!
Thanks to everyone who tossed their 2 cents in. I sure appreciate it.
Tom in TN
Old 08-24-2023, 08:38 PM   #26
Bored&Stroked
Bored&Stroked's Avatar
Great news! Glad you have it sorted out and that it is running well . . . now drive the heck out of it!
Old 08-25-2023, 06:55 AM   #27
mfirth
That is GR8 news. Now, I hope the Pertronix doesn't fail for you like some I know of have. No replacing simple parts here. When it quits, it is done .........
mfirth is offline   Reply With Quote
Old 08-25-2023, 10:42 AM   #28
Tom in TN
Tom in TN's Avatar
True, but out of 3 of my cars I installed them on- I have had no failures...as of yet. :-)
and to be honest I believe I could replace the Pertronix module without pulling the dist.
Could I do that with points...??? I kinda doubt it.
Old 08-25-2023, 07:18 PM   #29
32philly
Been having lots of condenser failures lately. Mallory is the worst.
32philly is offline   Reply With Quote
Old 08-25-2023, 07:21 PM   #30
32philly
Glad to hear you fixed your Ford!
