07-26-2023, 07:11 PM | #21 |
Re: S10 T5 into a 41 truck
Thanks Krylon . . . any idea on the actual dimensions on the input - from the front of the transmission? It might help folks find transmissions to use your kits - which is good for everybody.
07-26-2023, 07:14 PM | #22 |
Approximately 7.25
07-30-2023, 02:47 PM | #23 | |
Best Tony
Nomad |
07-30-2023, 04:14 PM | #24 |
Check my ad in the 4 sale section for a list of what's included and the price. I have them in stock for the 85-92 and 93 up S10 T5 trans. My kit has everything but the clutch disc.
07-30-2023, 07:54 PM | #25 | |
Gary ..... I believe Tony is asking about a crossmember similar to that pictured BELOW which accepts split wishbone ends/trans mount. I don't see one listed in your kit. Coop |
07-30-2023, 08:36 PM | #26 |
07-31-2023, 10:09 AM | #27 |
This is the Hot Rod Works mount. This is the type that didn't work for my application. I had to make one were the Heim joint was vertical rather than horizontal like these mounts. If someone wants one I'm pretty sure I still have the one I didn't use.
07-31-2023, 10:44 AM | #28 |
07-31-2023, 02:30 PM | #29 | |
That one is for the REAR radius rods. The one Tony was asking about is for the FRONT wishbone and also serves as a transmission mount. Coop . |
07-31-2023, 03:19 PM | #30 |
There are kits sold that are made to replace the entire center section of the frame. Speedway Motors shows them (TCI Engineering 204-2073-00 TH350 Transmission Mount-1937-1940 Ford). I have never seen a bolt in kit that is made for the ball end of the wishbone. You could purchase the kits with or without the flanges for the split wishbone so I ordered the one without the split bones mounts and built my own ball mount. It's basically the same idea as shown in the video above.
07-31-2023, 03:36 PM | #31 |
The picture above is what 40ragtopdown over on the HAMB manufactures. It is a great quaslity product and about half the price of a TCI or CE kit. This installation seems to work best with split bones. I have had a few customers do the kit with a spacer to lower the bones for clearance, I have no idea what they did to clearance the center of the x for the T5. I've used the yellow Hot Rod Works piece for the rear bones with no problems.
08-07-2023, 06:08 AM | #32 |
Thx for all the info guys, I went to 40ragtopdown on the Hamb. He’s got the kit & also showed some pics of a guy who modified his to accept the unsplit wishbone w ball mounted similarly to the YouTube video In the original post in the thread.
Nomad |
08-07-2023, 11:03 AM | #33 | |
