Old 07-02-2023, 02:52 PM   #21
Krylon32
Default Re: 32-34 Tie Rod End Adjustment
Useless was the wrong choice of words.
Krylon32 is offline   Reply With Quote
Old 07-02-2023, 06:42 PM   #22
Graham Freeman
The basic tool I made above will fit between the backing plate and the end of the tie rod enabling adjustment to be made.
Graham Freeman is offline   Reply With Quote
Old 07-02-2023, 07:07 PM   #23
Ian NZ
Ian NZ's Avatar
Wasnt there a firm at one time making up the ball joint two half inserts out of some material other than steel so it would be trying make the steering easier.
Ian NZ is offline   Reply With Quote
Old 07-02-2023, 08:06 PM   #24
Krylon32
When I built my last 32 pickup I found some ball joint halves that were brass impregnated. I used them and they seemed to work alright. I may have seen some I believe that were Teflon lined?
Old 07-03-2023, 08:40 AM   #25
Robert/Texas
Robert/Texas's Avatar
I installed E-Z Steer Teflon seats in the tie rod and drag links on my '34 roadster and both Model A's around 10 or 15 years ago. I grease them regularly and they make the cars much easier to steer. I'm going on 89 now and I don't think I would enjoy driving the cars much without them. I think that I bought them from from C&G, Snyder's or Bratton's.
Robert/Texas is offline   Reply With Quote
Old 07-03-2023, 11:53 AM   #26
petehoovie
petehoovie's Avatar
Old 07-04-2023, 01:14 PM   #27
David J
David J's Avatar
Just in case this has not been mentioned.
Agree on tightening them tight and backing off NO MORE than 1 turn.
Really cuts down on "death wobble".
That said be sure to check for binding as any wear on balls will cause serious issues this tight.
David J is offline   Reply With Quote
