Old 03-18-2023, 10:49 AM   #21
pjdeb
pjdeb's Avatar
Default Re: Backfire! Help! So frustrated!
Just by trial and error. The one in the truck was the original problem. I replaced it with a "new" one and thought I was good to go. No, but I went on to other things as I thought I was good. Goose chase. Eventually changed to spare distributor. Better, but spark was weak. Put in another "new" condenser and she started right up and ran well.
That was after I discovered the loose wire between the plates. Do not know if that was affecting the condensers. Certainly did not help.
pjdeb is offline   Reply With Quote
Old 03-18-2023, 11:06 AM   #22
mcgarrett
We keep hearing stories like this over and over. If you think you're having ignition problems check the condenser first. That little part causes many problems and it's the easiest and least expensive to correct. NEVER assume that just because a condenser is new that it is good and this is especially true with NOS condensers. Condensers can go bad and cease to function just sitting it a box - some of the cheap Chinese imports were garbage the moment they were made.
mcgarrett is offline   Reply With Quote
Old 03-20-2023, 09:54 AM   #23
81ls1camaro
Originally Posted by Rob Doe View Post
PJ, how did you determine that the 3 condensers were bad?
I don't know what he did, but I use the capacitance check on my digital multimeter to check them.
81ls1camaro is offline   Reply With Quote
Old 03-20-2023, 04:08 PM   #24
Gene F
Gene F's Avatar
81LS1camaro, how do you do that? Out of the box, or do they need to be used a little first to excite them? Digiatal or analog meter?
Gene F is offline   Reply With Quote
Old 03-20-2023, 07:58 PM   #25
Mulletwagon
Mulletwagon's Avatar
PJ - Thanks for the final report. Always enjoy a success story.
FL Panhandle
Mulletwagon is offline   Reply With Quote
