Old 12-07-2022, 09:04 AM   #21
sjaakslinger
sjaakslinger's Avatar
Default Re: '36 221 - rebuildable??
Thanks a lot everyone for all the input.
@Mart
We tried to pull the pan yesterday, but thought we knew better than the repair manual. We couldn't get the pan past those radius rod (?). We did raise the engine though. The manual tells to turn the crankshaft, but the engine is stuck. We'll give it another try tomorrow. and loosen those rods.
I'll check out your videos, thanks. So the motor is still in the car. I was hoping to get a good impression on it's state before pulling the engine out. I did get a peek after lowering the pan a bit...same rusty wet look though. Didn't check the pan rail yet. Thanks for that mounting tip....we'll keep it in mind in case we pull the engine.
The car's history isn't really clear. It spent the last 20 years in a barn in Pennsylvania. It was last registered in '66, also in Pennsylvania. It looks like they did indeed work on the engine before. Till now everything came off pretty easily. Even the rusted exhaust link pipe and the exhaust at the manifolds. We inspected the bottom of the car. Looks pretty solid, besides the obvious surface rust. The car seems complete as well. I did take a hit at the left front some point, braking the bumper bracket and bending the fender and grill a little bit. It caused the left headlight to be a bit closer to the cowling. The chassis seems straight though.
Depending on the engine being an LB engine or not and salvageable or not I'll have to decide what route to take here. It won't be a full resoration in any case, but a technical restoration and just drive it. Slight interior improvement, rust treatment on the outside and go. Maybe juice brakes, depending on it's stopping abilities.[emoji16]
Dennis
Verstuurd vanaf mijn SM-T720 met Tapatalk
sjaakslinger is offline   Reply With Quote
Old 12-07-2022, 10:21 AM   #22
Mart
Mart's Avatar
Whatever happens, I can't imagine a scenario where the motor does not need to come out. I would advise just bite the bullet and pull it. (I'm a poet). If in doubt yank it out. (told you).
Mart.
Old 12-07-2022, 12:23 PM   #23
rotorwrench
rotorwrench's Avatar
I'd have to agree with Mart. The condition warrants work that is much better and easier done out of the car. As was mentioned, an engine stand adapter that connects the the exhaust ports is much better than worrying about cracking the rear bell area. The casting is not all that thick on the rear end there.
The one rusty piston is likely the sticking point. Just getting the valves out is a big job and they should come out to insure serviceability. If the engine was not so internally fowled and the cylinders were all still void of corrosion, things would be different. That one is just beyond that state. Everything needs to be cleaned & checked.
Old 12-07-2022, 02:14 PM   #24
sjaakslinger
Yeah, we'll probably pull the engine. I measured the bore btw, says 3.08". As far as this is accurate, the measuring caliper was a relatively cheap one.
Verstuurd vanaf mijn SM-G781B met Tapatalk
Old 12-07-2022, 02:42 PM   #25
Mart
Mart's Avatar
That's 17.5 thou over standard. Could be 15, could be 20 depending on how accurate the measuring method. Any marks on the good pistons?
standard bore is 3-1/16"
Old 12-07-2022, 04:13 PM   #26
Ggmac
Isnt std 3.087?
Ggmac is offline   Reply With Quote
Old 12-07-2022, 04:21 PM   #27
rotorwrench
It would 3 1/16" or 3.0625. If it was previouy overhauled with a bore job then the oversize should be on top of the pistons.
Old 12-07-2022, 04:48 PM   #28
jimTN
Its hard to tell from the pics but most of those engines had sleeves. The easiest way to work that bad cyl may be to break the piston out driving from below, worst case cutting the rod into, then -putting a sleeve in that cyl bored to match what you bore the other cyl's. As wore as the engine is I would suspect it will need boring all cyls.
jimTN is offline   Reply With Quote
Old 12-07-2022, 06:25 PM   #29
Ggmac
Thanks . It seems like Im losing it . One foot in front of the other .
Gary
Old 12-07-2022, 07:43 PM   #30
rotorwrench
I think the tin can sleeves came later but it depends on which block it has. The 21-stud block doesn't have as much room for sleeves as the 24-stud blocks.
Old 12-08-2022, 09:42 AM   #31
Rodrelic
Does it have water pump block off plates on the block just below the head mounted water pumps?
Rodrelic is offline   Reply With Quote
Old 12-08-2022, 10:22 AM   #32
sjaakslinger
99% sure it doesn't. Lots of mud and cr@p there, but at first glance I didn't see a plate and bolts.
Old 12-08-2022, 12:23 PM   #33
sjaakslinger
Well, we didn't manage to get the oil pan off. The engine is stuck, so we couldn't turn the crankshaft to clear the pan inside. So, the unevitable is next....taking the engine out.
I cleaned a small piece of the oil pan rail, but didn't see any cracks (yet).
I did get a peek inside though. Same rusty appearance. I was able to measure the distance between the most rear visible studs. If I'm correct, that's the rear main bearing? Measures around 3 1/4".
So am I looking at an LB engine!?[emoji850]
Old 12-08-2022, 01:18 PM   #34
bobH
Regarding that 3.08 measurement.... It depends on how that was obtained. If he measured BELOW the ridge, it likely just indicates a worn cylinder, based on standard bore. If he measured the diameter ON the ridge, then the 'puzzle' indicated in the previous posts still applies. (Opinion) In any event... I see a lot of work, and a fixable engine. And, if an LB, in my opinion, I'd go for it. (I'm prejudiced, I have some good memories with an LB.)
bobH is offline   Reply With Quote
Old 12-10-2022, 10:53 AM   #35
rottenron36
rottenron36's Avatar
Don't forget how hard it is to find rod bearings, and how expensive they are!
rottenron36 is offline   Reply With Quote
Old 12-10-2022, 11:09 AM   #36
flatjack9
flatjack9's Avatar
3 1/4" would be LB block.
Old 12-10-2022, 12:23 PM   #37
GB SISSON
GB SISSON's Avatar
Believe me, when I can 'start 'em in the field' and drive them away, that is my favorite kind of old truck adventure. I have pulled that off maybe six times in 50 years of picking up old fords. Those with mechanical brakes were extra fun because you actually could start driving them as is (if one happens to live on the back side of a rural island). BUT.... your engine is not a candidate for that particular brand of fun. They are sooo difficult to work in in the vehicle and sooo nice on a stand. Do yourself a favor and pull that bad tooth out. It will feel much better after that!
Old 12-13-2022, 11:24 AM   #38
sjaakslinger
Ok, working towards the inevitable...taking the engine out. We removed the grill and radiator as well as the passenger toe board and the trans cover plate. Next will be the shifter and clutch linkage.
Any tips/pointers for getting the engine and trans out? Where is the (approx.) center of gravity of the engine+trans? Might help in lifting... Thanks.
Dennis
Old 12-13-2022, 11:50 AM   #39
Mart
Mart's Avatar
Somewhere near here.
Old 12-13-2022, 12:13 PM   #40
sjaakslinger
[emoji106]
