10-11-2022, 05:28 PM | #21 |
Re: Mitchell overdrive
It is recommended to leave the tray in the Burtz engine because the big end of the rods create an oil fog that helps lubricate some of the engine parts. I am not sure that is true but I left mine in. I am considering drilling small holes (1/16 inch) in the bottom of each tray so that the oil completely drains out during an oil change. Don't do that with a stock engine as the oil in the tray provides instant lubrication for the rod bearings on startup.
10-11-2022, 06:51 PM | #22 |
Dont drill any holes, take it from me
Lawrie |
10-11-2022, 07:21 PM | #23 | |
It's here now though, so in it goes. |
10-11-2022, 09:13 PM | #24 |
If I remember right the Burtz is engineered for a sustained 112 mph.
If you have some of the Comp V tyres they are good for 149 mph so I guess you need to be careful. A lot of the oiling in an engine is done by spash. |
