Old 09-15-2022, 06:30 PM   #1
ndnchf
ndnchf's Avatar
Default Re: Electrical fire, now to figure out why.
Originally Posted by Smokedtires View Post
Thank you ever44-77yone. After checking everything, it looks like the cutout is causing the problem. I have a new one being delivered tomorrow so I will know more. Interesting all of the discussion on the cutout, that is how it was setup when I bought the car in June.
Your tips were all very helpful. Thanks again.
If its any help, I sell refurbished, original Ford cutouts. I can also test, and possibly repair yours. PM me if interested.
Steve
ndnchf is offline   Reply With Quote
Old 09-15-2022, 08:16 PM   #2
nkaminar
nkaminar's Avatar
The grommet is here: https://www.snydersantiqueauto.com/p...6244&cat=41801
Old 09-16-2022, 09:33 AM   #3
rotorwrench
rotorwrench's Avatar
That's for the armored cable. I was referring to the metal conduit that houses the generator wire and the battery wire on the 1928 and 29 models. The armored cable for the ignition uses the large grommet to stabilize the big wire wound flexible conduit. It also acts to limit moisture intrusion into the terminal box. It insulates only a small portion of the dash harneses against shorting in the area of the two terminal studs.
Old 09-16-2022, 02:58 PM   #4
Rob Doe
This is a great thread for me. Thanks to all who have posted here. Rob
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
