05-17-2022, 03:45 PM | #21 |
Re: How much rope seal do you leave proud?
05-17-2022, 06:50 PM | #22 |
A rope seal needs some preload to give equal force all the way around. Factors like gasket overlap can affect it. The Best Graphtite seal is a lot different than a white rope seal so they provide the tool & gauge to get it right. If too much rope seal is hanging out then it may prevent the pan from fully seating. The rope can apply too much choke force on the pulley or crank and may damage the seal after start up. All factors need to be taken into consideration for how much to trim. Pan gasket thickness plays a part. A thick gasket needs more protrusion than a thin one. Use good common sense and keep asking questions when in doudt.
05-18-2022, 01:51 PM | #23 | |
Yes if your referring to any early Flathead V-8 engines from 1932 to 1948. The oil pan rail gaskets have a tang shape that slips into the grove in the rear main bearing cap. Then the cork gasket that fits into the rear main bearing cap grove sits on top of the section of the oil pan rail gasket that is now located in the grove mentioned above. NOTE Place each end of the cork gasket that goes onto the outer surface of the main bearing cap onto the pan gasket first. Once you do that you now will see the cork gasket on the cap is sitting a bit high it now needs to be pushed/seated in the grove after the outer edges have been set in place. NOW THE FINAL STEP For additional protection from leaking place a small amount of RTV sealer at the outer areas where the cork on the cap is now sitting on the pan gasket. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
05-18-2022, 02:22 PM | #24 |
Great instructions. Thanks Ronnie!
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35). |
